Topic: 1970 GTX disc brakes (Read 230 times)
dotman
Hi everyone! I just purchased a 1970 GTX that came from the factory with front disc but somewhere in its life had drums swaped back in. What do I need to convert it back over. I would like to keep it as stock as I can. It is a n96 440 4 speed , dana car and is optioned out nice. Will the spindles need to be changed?? I have a freind with a 74 charger se that just installed lowering spindles and I could probable talk him out of the stock ones  . Will they work?? . I know or think I can still get the rotors-calipers-hoses from a auto parts store??. I dont know if the proportioning block is the correct one for disc or they changed that out also. Any help would be great. . Been out of mopars for a little bit and I can see I might need help doing the right thing to the car. So far the Disc and a AM- tape are the only missing items off the fender tag,Thanks in advance Rich
I'll see what I can dig up. We also need a pic of that GTX. I have a '69 RR.
Tom
Master cylinder part number 3420967 with a bail type cover, not bolt on. Should be a 1 1/8" piston. Calipers: Single piston Kelsey Hayes 2 3/4" diameter unlike the 4 piston used in '68 - '69. Right side PN 2944712. Left side PN 2944713. Rotors 11 3/4" . '68 - '69 were 11.19" dia. The B and E bodies used the same disk brakes in 1970. Year One list the calipers but I doubt they are factory correct. http://www.yearone.com/serverfiles/fbshopmain2.asp?cat=1Power booster PN 2883056. Brake pedal. Your GTX should have bright bezels for the pedal. You are going to have trouble finding the correct peices unless you don't mind ebay. I can't find 11" drums at the parts house anymore. I do not believe that a modern brake system would hurt the value of your car unless the brakes and radio are the only keeping you from 100 concours. Here is a kit that I have bought and it comes with spindles. http://www.mpbrakes.com/products/product-detail.cfm?product_id=235The booster appearance is the only giveaway. It comes with an O.E. style proportioning valve. If you need steel or S/S brake lines there is Year One or www.rightstuffdetailing.com. I have bought from both. Good Luck Tom
