Topic: Rear Quarter Glass Installation Help (Read 158 times)
HemiDoug
I can't seem to get my rear quarter glass installed in my '67 Dart HT. Can anybody advise the correct sequence for the glass and the rollers? Which end goes in first? The FSM is no help here.
Crazy68Dart
Get the regulator/tracks/rollers in there first. There are some holes in the sheetmetal that will allow you access to tighten the two bolts that hold the glass in place. Bring the regulator to the "up" position and install the glass and two botls. You will then have to adjust the regulator up and down to get the the bolts, possibly, to allow you to tighten them.
Hope this helps a little bit.
HemiDoug
There are a total of four rollers, three in the front and one in the back. One in front and one in back are not held on with bolts, but with snap clips that I don't think can be installed after the glass is in, as they are next to the outer skin with no room for a tool. I tried cocking the rear roller enough to get it started, and now I broke it!  I can't seem to find a vendor for this part. I will try removing the two large swiveling rollers and install them first. I hope I can get behind them to bolt them back in. Thanks.
gt
HemiDoug
I called Tom today at RT Specialties, and he came through, as usual. Now back to
