Topic: A-Body weight (Read 29507 times)
451 valiant
Online
Ontario, Canada
Finally got it weighed so here goes:
68 Valiant - 451ci, eddy heads, eddy rpm intake, stock 340 rad, 727, 8 3/4 sure grip, no p/s, no p/b,no a/c, heater box installed, all steel body and bumpers, full interior, bench seats, weld wheels, ss springs
3100lbs with 1/4 tank of gas and no driver.
383_Demon
Well, just weighed mine this morning.
'71 Demon Vinyl Top 'glass front bumper 400/727 Disks up front B-body 8 3/4 rear sub-frame connectors Centerlines Full interior (no cage, yet)w/'73 bucket seats aluminum radiator
3140 lbs (without my 225lbs)
darth720
1972 swinger all steel body ,1976 440 block/500 stroker , 650 lift roller cam ,short fill hard block,7 quart moroso pan,main guirdle,Victor Heads, Victor Intake,1000cfm hp Holley (annular boosters) , Aluminum Rad,two electric fans, Moroso electric water pump, aluminum w/p housing, mini starter, Hooker 2in fenderwell headers, 3 inch exhaust to rear diff, roll bar (mild steel), 8.75 diff (742)with detroit locker, back braced, MW caps & adjusters, SS Springs & snubber,CE shocks, 727 tranny deep pan with blanket, NC 4000 stall converter, 10x28x15 slicks, 15 inch street tires on ralley rims up front, full interior( carpet ,seats, etc), full street trim (wipers, heater, etc), firewall behind rear seat, stock gas tank (full of fuel), small fire extiquisher,holley blue fuel pump , 1/2 inch fuel line, drive shaft loop. frame connectors , 1973 disks front , C- body drums rear ,no stabilizer bar, no spare or jack, trunk empty except for battery. Glove box full of pushrods , msd chips , traffic tickets and a small aztec voodoo doll.
3480 lbs just car w/o driver
540dust
71 Duster lexan windows 2x3 subframe connectors mild steel cage 12 gallon fuel cell steel tubs back halved 4 link coil over power glide trans aluminum low deck block aluminum heads aluminum water pump and rad Alterktion front suspension aluminum wheels glass hood and bumpers the rest is steel support beams removed from the '73 doors stock dash and door panels stock floor pan and firewall dana 60 rear axle 2770 lbs -- 2996 lbs race ready 51.5% / 48.5% distribution favoring the rear
1971scamp383
1971 scamp.... all steel....383... aluminium intake.. aluminium heads... aluminium radiator..no power brakes..no power steering...electric fan.....tf727...b-body 8 3/4 with 11 inch brakes....all steel wheels...4 corner drums...frame connector...all original interior ..full bench seat....3245 lbs ... half tank gasoline without my 220lbs in it!!!!
...1971 plymouth scamp 383...
jimmyb
68 Dart double frame rail car 2406 without fuel and oil.
 Blown 572 Hemi Work in progrees
west
that's very impressive. just think without the blower it would prob weigh about 1000 lbs.
360/727/3.73 12.7 on street tires
