Topic: Learning to tig weld? (Read 350 times)
TrxR
Hey guys I was wondering if anyone knew a good book on tig welding?
I am looking at getting either a Dyansty 200DX or a Dynasty 300 soon and am looking for some good learning material .
375InStroke
How much do those cost? I've had a little instruction in welding, like just a few minutes. I've done gas, stick, MIG, and TIG. I found TIG to be the easiest. Like everything, practice makes perfect. If the welds are lumpy, you need more heat. If you get holes, you need less heat or more rod.
get Miller part #196 567 TIG fundamentals Welding CD
#170 555 Gas Tungsten Arc Welding (book)
they should just include this in the package if you mention the numbers.
if i am a good boy i may get the Maxstar 200DX soon.
mischiefdart
Make sure the lense for your mask is not too dark. Tig welding does not produce as much light as stick welding so it can be hard to see what you are doing with a dark lense. Tig welding is not hard. It is a lot like gas welding but a lot cleaner and more precise.
Check out the Monster Garage book How To Weld Damn Near Anything. Great book, under 20 bucks, in the book store in the automotive section.
TrxR
Looks good:) Congrats on the welder. Now I just have to get back to work so I can aaford mine as my last job ended a little earlier than expected but thats the breaks.
sunsetdart
Best advice for learning to TIG weld......Books can help get you started but the main thing is>>>>>...........PRACTICE, PRACTICE and more PRACTICE. The beads you lay down should look like coins on their side. Once they look like that , you got it down.
