January 08, 2009, 03:03:10 PM
| | |-+  STEERING LINKAGE AND OIL PAN INFO NEEDED
Author Topic: STEERING LINKAGE AND OIL PAN INFO NEEDED  (Read 269 times)
sassy383
« on: February 08, 2006, 07:19:52 PM »
I AM NEW TO THE SITE AND FIRST WANT TO SAY HI TO EVERYONE. I AM PUTTING A 383 IN MY 72 DUSTER THAT WAS AN ORIGINAL /6
CAR WITH ALL /6 STEERING AND K FRAME INSTALLED. I AM BUYING THE SHUMAKER MOTOR MOUNT ADAPTERS AND HEADERS. MY QUESTION IS CAN I USE THE /6 PITMAN ARM, IDLER ARM, AND STEERING LINKAGE WITH MY 383? AND WHAT OIL PAN DO I NEED. I JUST
DO NOT WANT THE STEERING TO HIT THE OIL PAN.
Re: STEERING LINKAGE AND OIL PAN INFO NEEDED
« Reply #1 on: February 08, 2006, 08:28:08 PM »
You best bet is a C body pan stamped 187 or 699 some are not stamped but are the same.  The steering linkage may or may not hit and if it does a V8 link might give you some more room.
« Reply #2 on: February 08, 2006, 08:33:50 PM »
Did you read this article on the schumacher web site?
http://www.engine-swaps.com/
And by the way welcome to the site.
The link won't open to the article so just scroll down on the left window to the car craft article.
Sacramento CA.
« Reply #3 on: February 08, 2006, 09:02:15 PM »
Out of all the A body's I've taken apart I have yet to see any difference in the /6 to V8 drag-link. There are 2 different ones for the 67 to 76 A body's. One for the 67-72 which the idler and pitman arm mount form the bottom and one for the 73-76 that they mount from the top.
mopar975
« Reply #4 on: February 13, 2006, 02:18:58 PM »
Will the older swap into the newer K member?
Sacramento CA.
« Reply #5 on: February 14, 2006, 05:10:13 AM »
Yep all will except the 67 odd ball idler arm. You have to keep the center link, idler arm, and the pitman arm together as a set-up.
