January 08, 2009, 03:35:09 PM
| | |-+  After market Disc brakes A body, whats best- & will I
Author Topic: After market Disc brakes A body, whats best- & will I  (Read 638 times)
LAWFISH
LAYING DOWN SOME MOPAR JUSTICE
« on: July 30, 2007, 04:01:26 PM »
I am going to put after market disc brakes on my 67 Dart/ front end. I want the large bolt pattern and dont want to search the ends of the earth. What is a good brand for the $$ and when I purchase a set. will I stil need the later mod Disc brake upper control arms or are they provided or adjusted for?  Are there any other parts I need to find. Looking for aftermarket not some other older mod mock up.
thanks for the help. which brakes do you guys like.  I am not sure what motor is going in this 67 dart yet but I am working on getting my buddy to part with his 1970 340 that is done with a 6 pack set up. If ot, then I guess I have to send off one of my 440s for  a stroker rebuild from 440source.
In either case, I want it to stop and will also need a front sway bar.
LAWFISH
70 CUDA DRAG POLICE CAR
67 Dart POST 340-6 prokect and more
70 440-6 CUDA VERT
Caledonia, ON Canada
Re: After market Disc brakes A body, whats best- & will I
« Reply #1 on: July 30, 2007, 04:12:31 PM »
Does your Dart have 9 inch or 10 inch drums?  Most /6's had 9's, and V8's had 10's.  The spindles are different and limit some choices.
LAWFISH
« Reply #2 on: July 30, 2007, 04:20:01 PM »
I imagine they are 9 inch as there are 13 in tired/rims on it right now.    Wouldnt most complete disc brakes/ after market kits have the new spindles?    LAWFISH
70 440-6 CUDA VERT
« Reply #3 on: July 30, 2007, 05:29:25 PM »
I bought the kit from Engineered Components, and it was a nice kit at a good price, but it only fits 10 inch drum spindles.  I believe Master Power Brakes sells a kit that comes complete with new spindles and upper control arms.
« Reply #4 on: July 30, 2007, 06:06:25 PM »
Different kits require different parts. 13" wheels were standard with 9" or 10" drums. V8 a-bodies came with 10". If you need 10" drum spindles I might still have a spare set (if I didn't sell them already).
LAWFISH
« Reply #5 on: July 30, 2007, 07:18:30 PM »
OK, so I guess first thing is first, I have 13 wheels, so I have to pull the tire and measure the Huh? width of the brake drum? Or how do I get a spindle size, that way?
LAWFISH
70 440-6 CUDA VERT
« Reply #6 on: July 30, 2007, 07:30:20 PM »
Pull a wheel and look at the spindle. The nine inch upper part is twisted compared to the ten inch. Pics would make it easy to tell.
LAWFISH
« Reply #7 on: July 30, 2007, 07:40:01 PM »
I checked their site. I cant believe the prices. $1200 for the brake kit. I was thinking between $700- $800 for a kit. Those include the spindles.  I will go out and check, get a set of pics of the front end so I know what I am starting with.  LAWFISH
70 440-6 CUDA VERT
LAWFISH
« Reply #8 on: July 30, 2007, 08:11:55 PM »
Well,
70 440-6 CUDA VERT
LAWFISH
« Reply #9 on: July 30, 2007, 08:16:16 PM »
WellI pulled the wheel and the brakes look VERY VERY small, Jim you said  twisty, and I am no mechanic but this looks twisty to me, here are some pics. I am either going this 340 6 pack or a 440 to 500 stroker, so I need good brakes. Let me know what you guys reccomend. I do have some parts cars here a 70 duster, so I can always check the front of that.
I also have some 14 wheels that I am going to use for now that are sitting on a 68 post dart that I am going to sell and witch out the tire/rims until I can get the rest of the car done and swap out the brakes and rear end. I want the large bolt pappern all around and an 8 3/4 rear.
HERE IS THE LINK TO THE RESTO ON THE CAR. i BLOCKED all day today  I primed epoxy yesterday and many coats of K36/PPG today and the sanding started. I am no mechanic but I like to do my own paint here at home.
The car is also going to be a 4 speed car.
http://www.smithvalleymopars.com/67_hemi_dart.htm
LAWFISH
PICS
67 dart brake question
70 440-6 CUDA VERT
« Reply #10 on: July 31, 2007, 12:51:01 AM »
Yep, those are nine inch. The ten inch go straight up from the spindle to the upper ball joint, not to the front like those.
LAWFISH
« Reply #11 on: July 31, 2007, 02:11:57 AM »
So Jim, I need to buy a brake set that includes the spindles or buy a set of mopar one slike the ones you have or had? What does a set usually cost. I see some brake kits with spindles ncluded.
Dave
70 440-6 CUDA VERT
« Reply #12 on: July 31, 2007, 08:08:00 AM »
If you find some 10 inch drum spindles, the ECI kit is about $750.00.  Look under ECI Brakes.  Remember to factor in the price of new ball joints, master, proportioning valve, etc. when comparing to the complete kit.
uwee440
Tolland,CT.
« Reply #13 on: July 31, 2007, 08:12:33 AM »
Willwood makes a set for your 9" spindles  part #140-2722-B,I think I payed around $700-$750 for them. 4 piston calipers,vented rotors,billet hubs,easy directions.
Ray Barton Racing Engines
« Reply #14 on: July 31, 2007, 09:22:00 AM »
Look into SSBC.
LAWFISH
« Reply #15 on: July 31, 2007, 11:16:58 AM »
The ECI kit is $575.00 for what you see below.
The Wilwood is $673.00 for what you guys think is a better deal? And if I buy a kit like this as compared to a $1195.00 SBC kit, what do you think the remainder of the parts needed will cost? What type of master do I need since I guess this one in the 67 wont work? I have aomse parts car, B body and a couple of other items with brakes. Anything to use.
Maybe I should just bite the bullet and get the whole $1200 kit!
ECI KIT BELOW
WILWOOD KIT INCLUDES
Wilwood Dynalite Pro Series Front Disc Brake Kits
Disc Brakes, Front, Pro Series, Solid Rotors, 4-Piston Calipers, Dodge/ Plymouth, Kit
tHEN THERE IS ssbc KITS  link  http://www.stainlesssteelbrakes.com/products/searchByVehicle/Dodge/Dart/1967    And I would not even know which kit to start with here, they officer many many different systems. There are any where from a grand to $1300-1400. Do I need a 3 caliper or 4 caliper system?Huh
 Popcorn
70 440-6 CUDA VERT
« Reply #16 on: July 31, 2007, 11:44:27 AM »
It would be so much cheaper to just buy the swap components and peice it together yourself, if you used 1973 and later components, you could do it for about $500 complete. For another $80, you can upgrade to the 12" rotors.
« Reply #17 on: July 31, 2007, 01:04:24 PM »
DO NOT RUN THE NINE INCH SPINDLES. They are considerably weaker than the 10".
« Reply #18 on: July 31, 2007, 01:24:38 PM »
Check out the new issue of POPULAR HOT RODDING, they have a whole story on converting the 9" drums to WIllwood discs on a 68 Dart, total cost they had was $980, which included everything including new master cylinder.
uwee440
Tolland,CT.
« Reply #19 on: July 31, 2007, 06:59:02 PM »
I've had willwoods with the 9" spindles for 5 years,with no problems,including driving it on the street and at the track.People told me not to run the s/6 tortion bars  either and my car rides fine with those too.Of course it can't corner though.
LAWFISH
« Reply #20 on: July 31, 2007, 10:20:05 PM »
My buddy called me today and informed me he would sell me his rebuilt 1970 340 for my dart. Its a 70 and now is rebuilt has a brnad new 6 pack manifold and all the trimmings and HP manifolds. I dont know what the manifolds go to, poss an E body, think they will fit in this dart. It also comes with a real 440-6 air cleaner, old school one. Hope to get it all for $4k. Would be my deal of the year and would be an easy swap. I know I know not a big block. But I am just finishing up the 650 HP 500 stroker for the 70 Cuda lawfish drag car, so I am a little stretched and I am trying to get a ton of stuff done on the property in idaho and get ready for a move--so its all up in the air.
Now, I need some brakes. !nanr
LAWFISH
70 440-6 CUDA VERT
« Reply #21 on: July 31, 2007, 10:25:51 PM »
I just bought a Wilwood kit, so I have some VERY low usage rotors and calipers w/brackets for sale.  It's 74 Duster stuff, large bolt pattern with bearings and everything.  All you'd need is the spindles and UCA's.  PM me if you're interested.
Carter
« Reply #22 on: July 31, 2007, 10:38:56 PM »
i pieced together my front brakes for about $500 for the 11.75 inch (stock) rotors
if you want to get more of a kit, i would go with the ssbc brakes, the ones that have just an adapter bracket plate just dont settle right with me
you absolutely dont need 4 piston calipers, unless of course you are going to autocross it or you want them just for show,
i use a 1 piston 73 b body caliper and i love it, really lightens up the pedal over the stock a body caliper and you have plenty of feel
i can stop from 60mph to 0 in 105 ft, and i dont need the shiny bling kits to do it
440Demon
Streetsboro Ohio
« Reply #23 on: August 02, 2007, 01:06:24 AM »
This is the Wilwood set-up I put on my Demon.
Now it is for sale  CHEAP...
I bought an Alterktion front end and can't use this set-up.
It is all new, no miles..
PM me or e-mail me if interested.
hemi_jay
Mopar FTW!
« Reply #24 on: August 02, 2007, 02:33:54 AM »
I bought the Willwood kit for $672 from Summit for 10" spindles. They look great, and Im sure they work just as nice.
vitamindart
« Reply #25 on: August 04, 2007, 01:01:21 AM »
i'm not a fan of the eci or scarebird stuff as the usually use gm style calipers ,i run the stock 73 up stuff as i'm to cheap to buy the wilwood stuff right now
sr71mopar
Santa Rosa, CA.
« Reply #26 on: August 04, 2007, 01:36:49 AM »
And the wheel bearings are very small.
tubtar
« Reply #27 on: August 04, 2007, 03:55:23 PM »
https://www.reillymotorsports.com/
Try this outfit        ............ I got my kit from them.
It was complete with spindles and cake to install.
I opted for tubular upper arms W/ ball joints and new joints on the lower and was still under 900.00.
