January 07, 2009, 09:25:05 PM
| | |-+  getting hardened paint off of trim?
Author Topic: getting hardened paint off of trim?  (Read 278 times)
ValiantOne
Western MD
« on: August 05, 2007, 05:12:46 PM »
Been tryin' to get the paint off my trim where the masking job was less than adequate. Laquer thinner won't touch the stuff. I'm guessing it is enamel. Is there anything I can use other than stripper?
Thanks,
Chris e.
Chris Evrard
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
Long Island, NY
Re: getting hardened paint off of trim?
« Reply #1 on: August 05, 2007, 05:34:28 PM »
Can you get the trim off the car? Rock Miracle will take off any paint, but if you get it on the car, it'll destroy that paint as well.
Allentown, PA
« Reply #2 on: August 05, 2007, 05:44:22 PM »
if you cannot get he trim of the car  try and put a piece of masking tape beween the tape and paint then use fine steel wool to remove the paint from the stainless and then ploish with your favorite polish and remove tape ...
eldubb440
Go Phillies!
eldubb440
« Reply #3 on: August 05, 2007, 06:05:37 PM »
this is why i just take everything apart BEFORE painting.......we all learn this lesson at some point
71 demon child
« Reply #4 on: August 05, 2007, 06:44:58 PM »
Sooo true.I've used a razor blade before to get the majority off.Not for the weak of heart though.I really wouldn't suggest it.Just a last resort sota thing.
carl
taking donations
ValiantOne
Western MD
« Reply #5 on: August 05, 2007, 08:09:14 PM »
Guess I should have been more clear.
Yes I have taken the trim off the car and need to clean it up.
What is Rock Miracle?
The butt heads that painted this car should have been shot Gangster
Chris Evrard
GON_RACIN
Happiness is a warm gun.
« Reply #6 on: August 05, 2007, 09:50:57 PM »
Tal-Strip on a Q-tip maybe?
Long Island, NY
« Reply #7 on: August 05, 2007, 10:19:42 PM »
Rock Miracle is a badass paint remover. It works best when the temp is 70 degrees or more. It doesn't do much when it's cold. It should be available at a hardware store or maybe a paint store. I don't ever remember seeing it at the Depot. I'll look for a website.
eldubb440
Go Phillies!
eldubb440
« Reply #8 on: August 05, 2007, 10:41:46 PM »
if the trim is off the car id try paint stripper.......just dont use it on plasic
Long Island, NY
« Reply #9 on: August 05, 2007, 10:48:29 PM »
http://www.rockmiracle.com/
I'm talking about the original in the white and red container. I wasn't aware they made all that other stuff.
sunsetdart
us4ever365@hotmail.com
« Reply #10 on: August 06, 2007, 07:13:46 AM »
Besides using a paint stripper, a good cutting compound should take off that paint as well.
4spdfury
« Reply #11 on: August 07, 2007, 09:44:06 PM »
 if its off of the car just buff it
68S
« Reply #12 on: August 08, 2007, 09:56:17 AM »
If the trim is aluminum you may not want to use paint stripper as most of them contain sodium hydroxide (lye) which will remove the protective anodized coating. I have never really tried this on anodized aluminum but brake fluid seems to remove most types of paint and is safe on plastics.
Pat
