Pages: 1 [2] 3 4
Topic: Racecar specs!! List your specs - helpfull info.. (Read 13264 times)
Mopartist
For those of us dreaming of someday getting our cars into a respectable elapsed time on the quarter mile; I was wondering if we could get a glimpse of some of your stats to get an idea of HP vs. Weight and your best ET ?
Dartsport
I started a Topic about 3 weeks ago with racecar specs, and ets., I will see if I can find it. A few people posted on it. Maybe we can get it stickied.
Bigcube
2975#, dyno'ed at 850hp, best ET to date is in my sig, that was in 3000' DA. I know it will go 8.90 on a better day in the fall. I have found this http://www.wallaceracing.com/et-hp-mph.php to be very accuate but it depends alot on how well your chassis works.
Dartsport
COULD we get this TOPIC stickied?? Some good info for people. Could we also keep to the topic !!
Dartsport
Bigcube
At 3000# with driver you are looking more like 9.50-60's around here. I might go a .4x on a good fall day though. Should be a fun ride
Newbomb_Turk
Thanks Jim, and everyone with your help, I'll be thrilled with that kind of times, never expected anything like that, I hope you're all in the ball park, now I guess I'll have to get a license and re-certify the chassis Thanks, John
496dart
70 dart 493 ci 10.8:1 Eddy heads 84cc --comp valve springs Straightline solid cam 259/266 at .050 -- 615 lift hooker fenderwell headers full 3" exhaust 1050 carb M1 intake Aerospace 350 gph fuel pump / -10 lines Msd coil MP chrome ECU MP distributer 727 w/ manual TA valve body TA stall--4500 4:10 gear 29.5 x 10.5 Hoosiers WEld wheels glass bumpers and hood SS springs with MP shocks Dana 60 race weight is about 3350 lbs with driver Still sorting out the car-- so far a 10.88 at 124 --- 6.88 1/8 mile at 100 -- best 60' is 1.48 I havent raced it in good or normal weather conditions (or the car running proper) yet either!  (still havent , as of 8-15-08 ! )
67 dartgts
496 dart: Looks good i am curious as to a couple things. 1. are you using a transbrake? 2. Why did you bring the gas line from tank up the firewall instead of having it feed the carb from the front of engine bay? 3. Where did you get that 3 mile long radiator hose??  Seriously it looks great i only wish mine performed as well,,but it's getting there. Maynard
67 dartgts
1967 Dodge: Dart 2 Door Sedan 3000 pounds (no driver) New floors Custom built transmission tunnel New quarter panels 6 Point Roll Cage Frame Connectors Fiberglass Hood / Front Bumper and brackets Rend End Assembly: Strange Eng. Mopar S-60 (Dana Style) Track Lock 4:10 Gear Ratio Street & Track Axle Pinion Snubber Transmission: built by Ron Mancinni Mopar 727 Reverse Pattern Turbo Action Turbo Action Converter Turbo Action Shifter Contender CO2 Shift Unit 1971 440 block .060 overbore (452 cubic inches) Stroke: Standard Balanced rotating assembly Magnafluxed /Decked / Align Bored Pistons: Keith Black # KB237 5cc. Flat top single relief 5cc head volume Compression Ratio 11.50 Zero Deck CAM: Comp cams # 23-631-5 solid lifter Duration in 256 ex 266 @.50 in. 274 ex 262 Lift .550intake .579 exhaust lobe sep 108. Rocker Arms: 440 Source Roller shaft & tip 1:5 ratio Heads: Edelbrock 440 Performer 84 cc Aluminum Fuel Sytem: Barry Grant Pump: 480 Gallons per minute with regulator 5 Gallon fuel cell with all braided lines Intake: Weiand Team G single plane high rise Carburetor: Holley Race Dominator 1050 CFM Exhaust: TTI 2 Inch Under Chassis Ignition: MSD Pro Billet Dist Controller : Mopar (MSD AL6) Launch Controller : MSD Still working out the bugs. Hopefully will post a decent time soon..  Maynard
496dart
496 dart: Looks good i am curious as to a couple things. 1. are you using a transbrake? 2. Why did you bring the gas line from tank up the firewall instead of having it feed the carb from the front of engine bay? 3. Where did you get that 3 mile long radiator hose??  Seriously it looks great i only wish mine performed as well,,but it's getting there. Maynard 1. no trans brake (maybe next year) 2. the gas line was a major pain to install--so, i ran it where i could, NHRA tech hasnt said anything about it--probably because i have a trans blanket... 3. I searched forever to find a hose that would work with my new Griffin radiator---thats the ONLY one in O'Reiily stock that would come close to working ! If you run a 90 degree water neck , i bet more hoses would fit.,... Oh well--the car doesnt overheat....
496dart
Hell Maynard--------looking at your combo id say it should go at least 10.50 with some good slicks under it  !
67 dartgts
Well I hope it goes that well ...got Hoosier 29 x15 x12 Slicks. Maynard
Mopartist
Yeah; i wasn't really sure if it could be compared down to a science. I just figured if we had a good average baseline we could look at; we could kinda get an idea how much weight we should trim vs. Horsepower goals to get an idea of an ET range we are shooting for. For me; with my 65 Dart; I'm planning on either a 392 or 426 Hemi in the 500 HP range; with 4:10 gears, and hoping to break in to the 10 second range (if all the other parameters come together that is. ie. traction; good air;....strong tail wind)  Thanks for posting the thread!
Bigcube
Your ET / MPH computed from your vehicle weight of 3000 pounds and HP of 500 is 10.58 seconds and MPH of 126.58 MPH. From Wallace, I guessed at the weight. Your chassis will need to work very well to run mid 10's with 500 hp.
PinkE
A New Journey Begins.....
I merged the 2 topic's and Stickied them...This is a good thread, keep it going...
dusterdarryl
wow what a cool thread, I cant stay out of this one, so here goes.. still under constuction is my 70 duster, 1/2 chassi'ed with a 4 link and full floating 9" 4.56s, 31x15.5 M/T sportsmans engine #1, is a stock bore 66 440 with flat tops, comp hyd 540" 241 @ 50 915 heads with 2.14s & 1.81 stainless valves, crane dut iron rockers, torker II & 850 holley. ign is all mother MoPar for now, I will use this engine to tune the chassi, get the car reliable and hopefully see some 11s current trans is a full manual 727 with a 9" 3800 J converter, engine # 2 is a B block stroker
eds dart
68 dart. motor is .030 over 440 offset grind crank (3.9) stroke comes out to 464 cu ". heads one 906 one 346 2.14/1,81 valves home ported no flow #,s. mopar .620 flat tappet probe roller rockers. je dome pistons about 13 to 1 pro parts headers. Msd 6al hvc coil victor 850 apd alky carb. 8" ati stalls 5200 a&a transbrake tranny roller rear support bolt in sprag. dana with 4.30 pro gear 4 link with anti roll bar 33x17 goodyears stiff sidewall. car weighs 3050 with me in it. with 4.88 gear in it 2 years ago best 9.98@ 132 in 1/4 6.29@111 in 1/8. with current 4.30 gear 10.19@ 129 in 1/4 6.38@ 108 in 1/8. dedenbear scc-3 2 step throttle stop autometer recording tach stock front suspension motor plate 12 point cage.
496dart
damn Ed !! That thing flies!
the340man4ever
OK I'll give a run-down of my car. 1974 dodge dart swinger 2dr. 3300lbs w/driver 10:1 measured compression 440 w/ 509 hyd cam. 906 iron heads w/ 2.14/181 valves from McCandless shop when they were still around. M1 single plane w/ 850HP double pumper pro-parts headers, electric fan and water pump drive. 727 auto w/ forward pattern man valve body and 9.5" Dynamic converter (high gear flashes to 4800). 28x9 hoosierdaddy slicks 4.30 gears 002/003 superstocks w/ 5 degrees nose down pinion angle,cheap Mopar long race shocks on back and competition engineering 3 way adjustables and 6cyl torsion bars up front. Footbraking from 1800 rpm runs 7.13 in the 1/8th at 95 mph. 60ft 1.52. 36 degrees total ignition timing. ethanol blend pump gas.
512Duster
I have 2 cars 77 Volare 3645 lbs with me. Its a street car first, race car second. .040 40, 383 crank and rods, KB 240 pistons at zero deck, home ported 452 heads, custom ground comp solid .520/.530 mid 240's @.050, 1.5 rockers, RPM intake, 750 pro form bodied Holley, 1 7/8 hooker headers, 3" exhaust, 3500 stall 9.5" converter, 4.10 gear'd Dana 60 with 26" ET streets. This year it has run 11.75@115 on 87 octane and so far has won 3 events this year. Vid of 11.90 http://ywnv.vidiac.com/video/79d53c31-439f-46f2-b877-998400210389.htmVid of Open Comp http://ywnv.vidiac.com/video/ae6fcd81-479e-453f-b50b-998400261f89.htmI'm just about to bring out my 70 Duster Race car Its a back half Ladder bar car. I'm thinking it should weigh around 2900lbs with me. .035 400 block with 440 source 511 rotating assembly. I went with 24 cc dish pistons and a 10.6-1 comp ratio for pump gas. Cam is a custom comp solid from Dwayne Porter as is the one in my Volare. .600/.600 266/270 @.050, Indy 400-3 intake with 1050 Domonator, Currently cnc ported E heads, 1.6 rockers, 2" TTI headers, 3.5" full exhaust out the back bumper just inside the wheelie bars, 5000 stall 8" converter, 727, 4.56 geared Dana 60, 32X14.5 slicks. Looking for high 9's. I'm hoping to have it out in 2 weeks. I was not ready for the first points race in the SS series so I decided to chase the points in my Volare which was a good idea as I'm 1st and 3rd in the 2 classes I run with it.
72dart
It's fast but will be much faster soon, trust me!
This is a GREAT THREAD!! I'm still under construction so no ET's yet but here it goes...440 stroker 4.375 bore x 4.15 stroke, H-beam rods, Ross custom 14.2 compression pistons, Crane custom mechanical roller cam 758in/752eh with 1.6 Jesel rockers, Ferrea 2.25 intake and 1.81 exhaust valves, titanium retainers, 7/16-3/8 Manton push rods, Rollmaster double roller timing chain, Charlies 10 qt S-comp pan w/Melling single line swinging external pickup, block filled w/hard block, BRC aluminum main caps, 440-1 Indy CNC'd heads, 440-14-15 Indy dominator tunnel ram intake, 2 1050 dominator carbs, CSR water pump, BG 400 fuel pump. Car is a 73 back halved Cuda, 5 gallon fuel cell, 4 link suspension, magnum force tubular K with rack&pinion steering, 12 pt cage, 727 trans w/TCI trans break and 8" converter. Car weighs 2553 lbs. I'm waiting on my Indy carb linkage, should be here Tuesday. My converter has the 7/16 bolts. I still need to get a flywheel and flexplate before I can drop this in!! So what is the best setup being used for these two items. I want to use the traditional bolt holes with a mini starter so I imagine I need the larger flywheel not the 130 tooth? What SFI plate and flywheel are you guys using and is it steel or aluminum? I was thinking aluminum would be better for weight etc. Help me out so I can get this thing dropped in and to the track ASAP to put up some numbers. I just finished painting the block and phew does it look good. I need to notch my motor plate a little to clear the Indy timing cover and then the water pump and plate go on.
deadly dart
We got 4 passes on our racecar now and saturday night in 96 degree weather with 155 degree track temp and spinning the tires off the line it ran a 10.25 @130 mph with only a 1.44 60' if it would have been cooler it would have gone 9's without a doubt.
540dust
540 inch low deck aluminum Indy block 4.5 bore 4.25 Bryant crank, 6.76 C&A steel rods, 440-1's w/2.25 valves and a .650 290 at .050 flat tappet cam and a single 1050 dominator and 14.92:1 static compression ratio. Trans is a 1.80 glide, rear axle is currently a 4.56 but most runs have been with a 4.30, tires are 104.25 roll out, converter is Coan 8" with 6100 at the gear change but Im experimenting with a 9.5" currently (mostly unsuccessfully, to my surprise it likes the 8" better). The car is a back halved 4 link with an Alter K front suspension and weighs 2997 with me in the car. Best et has been 5.79 with the 4.30 (but picked up about .04 with the 4.56 gear change ran a 5.83 with a 1.26 60ft in about 3000' of air). Have not ran quarter mile yet with this combination.
eds dart
thanks 496dart. i have been pleasantly surprised by how well this combo runs. the switch to alky carb was worth .06, the stuff really works.
moparmc
Just about finished this - 517 inch low deck(4.375'x4.3") best machine aluminum cap, bottem end girdle, 6.7" H beams, 13.3 comp, 440-1 345cnc 2.25" intake flow 380cfm, 1.7 Jesel rockers,1095 king demom r/s, Isky roller 282/286 @.050, 0.750" lift, milodon gear drive, milodon duel line swinging pick up oil system. magnafuel prostar 500 fuel pump, 727 a&a t/brake, billet drum, 9" Lupo convertor with mechanical diode. 9"diff 4.3 gears. 3250lb A body with coil overs front and rear, ladder bars and wilwood brakes all round.
B1Valiant
Well mine is a 572" Hemi. It is built using a mega block, and a 4.5" Bryant crank. I beam rods 13-1 compression a .759/.736 solid roller, Stage V heads and rockers. Indy intake and had an old style 1050. 4.10 geared Dana 60 with a powerglide. Last time out timing was at 29 degrees DA was 2650ish most of the day and the air temp was 100+ on a slippery track. Car with me weighs 2860, it is a mild steel 4 link strut tube chassis. Glass front steel doors and truck lid with lexan all around. Car went 8.90 with a poor 1.37 60' at 153+mph. I have made a few changes like carb, timing, new tires etc and we will see what it runs soon. Car should go 8.70's on a good track in similar air. It is usually run on the stop so never has been optimized for all out stuff. We will be running it in brackets and S/ST, should be 10.90 at 151ish..I have more info if anyone is interested..
rebel
theres a lot more potential in my car but i just wanted to build a bullet proof combo so i can race 9.90 supergas with minimal parts failure & the only unreliable component is me. Indy maxx low block , 0.035 over, KB forged pistons, H beam rods & chamfered crank. 440-1 heads, 400-2 intake, 1050 4150 series race demon, comp cams flat tappet cam 280@.050,dry belt cam drive, homemade crank scraper & alloy pan, milodon external pump with remote HP6 filter, reverse flow water pump, Holley Pro Strip Anihilator Ign,TA 5000 stall converter,TA brake,B&M deep pan, B&M supercooler with fan, Holley volumax fuel pump. car weighs 2850lbs with my fat butt in the chair. has Comp Eng back half kit, Romac floater hubs, f*rd 9" with 4.8 gears on strange nod housing & spool, 32x14x15 slicks. with timing only totalled out @32* & a super lazy advance curve(still not all in at 6000) 1.3 60's 9.90's @ 132mph. with timing at 35* 9.6@139mph.
