September 07, 2008, 01:20:09 AM
Pages: 1 2 [3] 4 Go Down Print
Author Topic: Racecar specs!! List your specs - helpfull info..  (Read 12419 times)
Bill LBSR
« Reply #60 on: August 23, 2007, 03:42:02 PM »
My car is a 1968 Dart Post, All steel except for front bumper and cowl hood. 400 block w/ 4.15 crank, 440-1 heads, Pro Systems 1050, powerglide with PTC convertor. Dana 60 w/ 4.10's. Stock front suspension, SS springs and stock rear suspension, 295 M/T Drag Radials. Car weighs 3440 with me in it, and its been 9.70's on motor and 8.70's at 155 on spray.
ou812
« Reply #61 on: August 27, 2007, 06:30:01 PM »
71 duster, 3120lbs., street/strip car...more strip now, ladder bars, coilovers, 28x11.5 Mickey slicks, dana 60, 4.56 gear, dennys drive shaft, 904 low gear set, 5700 flash A1 converter, stock front end with /6 bars, RMS upper A arms, RMS front struts, stock disc brakes, Koni SPA 1 front shocks.
Engine is a 360, .040 over, KB Hyper pistons, stock rods, stock crank (internally balanced), hard blok'd, stock caps, Isky solid FT cam, W2 econo heads, ported by me, milled about .115 for a chamber volume of 51.5cc, compression is 12.25:1.  Edelbrock victor intake, Holley 950HP carb, msd dist., wires, ngk plugs.
Cars best is 10.53 at Pomona...D.A. was about 1900-2000ft.  Overcast and in the summer.
Usually runs 10.60's -10.70's.  I changed the trans and went to std. gear set and it lost about .015!  This is the engine that I just dyno'd at 529HP.
Brian
www.immengines.com
www.neilhepburn.com
'71 Duster street car
10.53 best @126+mph
1.42 60 ft. best
W2 360
Chris_Holliday
72 dart 440, 906's, .509 runs 12.30's
« Reply #62 on: September 12, 2007, 07:46:44 PM »
Ok, I really love posts like this and I have a mild street/bracket combo for my limited budget. drag tree
1972 dart swinger, stock front bench and rear seat with no carpet giving me 3400lbs with me in the car.
I use a 440 with the stock cast flat tops, steel crank bottom end and windage tray.  I think the compression is around 8:1 with the unported 906 heads and steel shim gasket as the cranking compression was around 90psi.  It must be the low compression that allows me to use 18 degree initial timing and 41 total with a stock electronic ignition.
The 906 heads have 2.08-1.74 valves, crane ductile rockers and I use the .509 purple shaft.  I get the exhaust through schumacher tri-y headers with a short extension pipe.  I installed the cam straight up.  I run a street dominator intake with a 1" open spacer, crossover blocked with the valley tray, and 850 double pumper with 50cc pumps.  The engine is held in place with the 3/8" jegs elephant ears and a front to rear limiter.
I use a stock gas tank with 3/8 pickup and line feeding a high volume mechanical pump.  I use and electric water pump, aluminum radiator and electric fan also.
The 727 has a manual reverse valve body and a 9" 3800-4000 turboaction stall converter.  The front suspension has /6 torsion bars, 90/10 shocks, and disconnected power steering.  I made a set of frame connectors from the info on the tech page.  The rear is a 68-69 B body standard width dana 60 that I had 3.73 gears installed and a pinion snubber.  The rear is held in with the 002/003 superstock springs and long mopar drag shocks.  I use the stock 14" polyglas front tires and the rear are 26 x 10 ET drags with tubes on 15 x 10 weld wheels.
     All this is good for low 1.7 60 foots, 7.8 1/8 mile times and 1/4 mile times in the 12.30-12.50 range with 104-107 mph at Quaker City raceway here in Ohio.  This is a very basic combo and my first mopar project.  These cars are very easy to get into the 12's using stock parts.  I can't wait to build another. 4 speed
Ohio
383man
« Reply #63 on: October 06, 2007, 05:32:06 PM »
Well mine is no race car as its a street car I drive when ever I can including driving it to the track. But here is some info about it.
It's a 1963 Ply Sport Fury with an all stock body that I put a 6 point rollbar in.  The leaf springs are the original ones and it has air shocks at this time until I put SS springs on it.  It has a basic 440 that I built to sorta look like  Max Wedge but I dont have a crossram yet. It is a stock bottom end 440 thats .030 over and has a stock crank and rods that I bushed for the KB quench dome pistons.  I use 906 heads I ported and cut to get a nice .042 quench and a street friendly 93 pump 10.0 comp.   Has the MP .557 cam and Isky iron rockers.  The Holley Street Dominator intake with a basic 850 DP.  A Mallory dist with the MP orange ecu box.  Hedman 1-3/4 headers and 3" exh with Dyno Max Ultra Flow mufflers.  I built the 727 with mostly stock Mopar parts and use a TA reverse manual valve body and a Dynamic 9.5 convertor that flashes about 4200 at the track.  I have 4.30's and use 29 x 11.5 Hoosier QTP tires.The interior is stock other then the rollbar and the car weighs right at 3700 with me and a 1/2 tank.  It is the stock gas tank and I ran 3/8 line and use the Holley red pump.  Only ran the 1/4 one time so far with a best of 11.66 @ 114 but it was a very hot day and I love racing it so I will be going out soon in the cool weather.  This is a cool post as I really enjoy reading about the cars.   Smiley   Ron
500DART
« Reply #64 on: November 17, 2007, 11:05:27 PM »
I think it would be great info if some of us could list our specs of our cars.  List as much info as you can. Other people could see what it takes to get a car to a specific et.   My book with specs is at my shop. But here is some info!!      505 cu. in.  -  440 block, no filler, no girdle, steel billet main caps, bored .030" , Callis 4.250" crank, Oliver steel rods chevy size, JE pistons, little over 14 to 1 compression, Brodix B1-BA or BS( I forget which is the big block heads \/][ Dunno) ported , Crower solid cam around .609" and .599" lift, duration?, custom built step headers 1-3/4" to 1-7/8" to 2" with merge collectors, M1 intake with 850 dp Holly , #92 square jetting, no power valves, double roller timing chain, 35*full timing, FBO ignition system ( no MSD), BG400 ful pump,  Shogun water pump and water manifold, custom built BeeCool radiator, shroud and catch can, #8 or #10 radiator hoses, CRT 727 super/pro2 transmission (rollerized, billet aluminium front drum, bolt in sprag, Griner billet valvebody, transbrake) ,Hurst 1/4 stick shifter, with air shifter, PTC 8" converter, flashes to 5300-5400 rpm, shift at 6100 rpm, cross traps at 6300 - 6400 rpm , 4.10 gears in Ford 9" rear, Mark Williams axles, ladder bar with coil over rear suspension, Alston chassis 2"x3" box frame, coil over front suspension, rack & pinion steering , Wilwood 4 wheel disc brakes. Hoosier 32" x 13.5"w x 15" .  Car weghs 2525 ,  2705 with driver. 9.458et, 141.35mph, 1.278 - 60 foot,
64 Dart in a Donut
« Reply #65 on: December 03, 2007, 08:45:33 PM »
even if i get made fun of, i have a 64 dart with a 4-speed, 73 340, 70 heads, 318 forged crank mild cam, 273 drivers exaust, 318 passenger, dual plane intakle and a 770 vacuum secondary holley. besides the holley it was built in the early 80s and needs to be rebuilt. it has an 8 3/4 rear with whiney 3.55 gears w/ posi, and 50 $ pep boy tires. the closest quarter mile is 4 hours away, ran low tens in the 1/8 mile without power shifting, losing traction in all three gears i could get to. not one person i met down there was running a manual, people who noticed me lose grip every shift would wait at the timeslip booth to check out my primer dart. it was my first time and i am 17.
ksdartguy
« Reply #66 on: December 17, 2007, 09:16:13 AM »
Well this is my new setup, so I have no numbers to backup yet.
400 block bored .035 with 4.150 440 source kit 499ci. .010 down deck
with ported big valve 346 heads milled to 85cc for 11 to 1. Still waiting on cam,
but probably cam Crower roller, 262/266 @ .050 with .686/.692 lift with HS  1.5 rockers.
Comp 919 springs, TM6 old edelb manifold with 790 Holley E85 carb. It could use more,
but I had this already calibrated for e85. I also have a small plate NOS system I may use. 150HP.
Beefed 727, A&A VB and 9" J convertor, just back from PTC to be loosened to around 4200.
Truck Dana 60 that had 3.54s, new stange axles and spool with disc conversion.
Car went 10.90 @ 123mph, with the old 383 procharger motor. It weighs 3600 with all steel wheels and
My heavy (large frame)  Grin in it. Still assembling it all as well as moving the springs in for a little more tire room.
275-60-15 drag radials now.
1 3/4 ttis into full 3" with X pipe and magnaflows. Thats about it.
Rick              bbd sign
55robert@bellsouth.net
« Reply #67 on: December 20, 2007, 10:52:37 AM »
Hi !
 Here`s some of the stuff my (formerly Tweety`s) 557 Hemi`s got.
Kieth Black block 4.375" bore - Barton tweeked
  JE Custom pistons 11.1 : 1 built for a 200 shot (maybe some day )
  Bryant 4.625" stroke crank w/2.200" Journals
  RBRE Race Hemi rods (Oliver) 6.86"
  RBRE 896 Series tool steel tapered pins 1.031" x 2.750"
  ATI Damper
  RBRE 896 Series billet oil pump
  Milodon dual line swing P/U
  Charlies Pan
  Mopar Perf heads - Barton tweeked O ringed.
  RBRE 896 series S/S 2.250" Int.
  RBRE 896 series S/S 1.940" Exh.
  Comp Cams 1.540" Double springs w/ damper 450# @ 1250
  Comp Cams 10 Deg. retainers w/ Manley cups
  Bullet Racing Cams Int. 278@.050" / Exh. 284@.050 - .754"Int / .722"Exh.
  Comp Cams Roller lifters
  RBRE 2000 Rocker system w/ oiling updates
  IRC 3/8" pushrods
  RBRE Single plane Intake
  Gary Williams 1050 full race 1150 CFM w/annular boosters and reworked fuel   circuits.
  Hooker A-Body Hemi 2 1/4" x 4" headers
 The car is 2750 with me in it, has a light weight front half and has been back halfed with ladder bars and a floating 44" Dana 60 w/4.10 Stange gears, spool and axles and driveshaft w/ 1350 u-joints. I run 14.5/32/15   Goodyears for rubber. The car has Wilwood discs all around , 12 point mild steel cage  . The front end including the bumper is glass , the doors and decklid also . The trans is a J.W. Perf. Glide ' with Ultra bell adapter , The Wheel flywheel , J.W. transbrake , and 4600 stall 9" convertor. I`m using a Hurst Quarter Stick with pistol grip shifter also Hurst Linelock.
  How fast will she go HuhHuh? Not done buildin' er' yet !!! It was dyno`d at Bartons at 874 hp @ 6800 and 750 ft/lbs @5350 ....in a 2750# car , do the math !
   CAN`T WAIT !!!!!!!!
           Chryco Wink
    8.54 seconds shifting at 7200
truegrit0
« Reply #68 on: December 30, 2007, 03:40:54 AM »
I am working on a 1974 Plymouth Scamp. Currently starting with a 383. It is zero decked. The pistons are out of the hole 1 onethousands. (i think that is what womanator sayed) Hoping to have it ready buy next season.
« Reply #69 on: January 05, 2008, 08:24:23 PM »
72 400 block bored to the edge of insanity (4.395") with ARP studs in mains
stock 3.75" stroke 440 steel crank (455CID)
(I refer to it as a 456 to avoid the confusion of folks thinking it has a 455 Pontiac in it)   \/][
11.41:1 Comp w/ CP custom pistons
Eagle 7.67 rods .990 pins w/ L19 rod bolts
Edd'y RPM heads ported by Ed Vicroy (300+CFM @ .700 lift) to STD port window (not max wedge) w/2.19 Intakes
Hughes Roller rockers (1.5) and hold downs
Comp cams custom grind solid roller cam .648 - .660, 275-280 @ .050"
Comp springs and lifters
Isky Titanium retainers
Smith Bro's custom push rods
MP M1 intake for a Dominator
Holley 1050 Dominator on phenloic  spacer
Hooker Super comp headers 2" pri.
Home made Oil pan (Franken-Pan-2)
3 1/2" Exhaust w/ Flowmasters ending at the axle
MSD 6AL
OEM Dizzy (Still unadjusted w/ timing light)  Roll Eyes
Mezerie Water pump
GM electric air pump modified to use as crank case evacuation pump
727 w/ manual VB built by Pro Trans
4000 Stall (Unknown builder)
4.57 gears  8 3/4
11x28 Goodyears or 15.5 x 29.5 Mickeys for street ops  4 speed
Alter-K-tion
Best of 10.72 @ 125MPH
3540# RR W/ driver
There's a 572 B1 coming soon too. Evil
Can you say here chebbie, chebbie, chebbie...   bat
blackbetty
« Reply #70 on: January 08, 2008, 09:27:11 PM »
Everyone here seems to building drag cars. Mine is going to be a roadracer. It is a 71 Dart that will have a full 2x4 box frame and 14pt cage. Corvette C4 front suspension and a custom 3Link rear. The wheels I have are 17x9 for the front and 17x10.5 for the rear.  I am using a 9" rear with 3.55 and Detroit trutrac. The trans is a tremec t56 with upgrades to handle 600hp. For now it will have a stock 400 with twin turbos but after I get the turbo system dialed in I will change to an all alumium motor. The interior will have sparco racing bucket seats and stewart warner guages.
Make the asphalt bleed!
74duster383
« Reply #71 on: February 13, 2008, 09:49:26 PM »
mine is a 74 Duster strip only, 383 bored .030, TRW dome pistons,, 906's, street dominator intake, holley 750 vac secondaries, 484/284 mopar cam, 1.6 source rockers, steel crank, stock rods.  727, reverse manual valve body, 9 1/2 Dynamic converter, 8 3/4 rear w/4.88's and a spool.  Weighs 3100 with me in it, best of 7.46 1/8th.  Only raced two weekends so far.  switching to a 850dp this spring and I'm gonna seal my hood scoop so it sucks only outside air.  Hope to pick up a tenth.
73 Charger
74 Duster Drag car
maxwedgedart
« Reply #72 on: February 19, 2008, 10:11:09 PM »
68 dart all steel factory glass 727 8 3/4 rear 12 point cage 440 60 over 452 cast heads dominator indy intake solid roller cam flat top piston stock 3.75 crank 1.6 rockers 391 gears 3370lbs msd 6al box line lock. best et 10.39@128 1.51 60ft 6.52@104 8th mile. read about it in the oct/nov issue of MOPAR ENTHUSIAST MAG! story by JIM VIGNOGNA BUILT BY JIM VIGNOGNA AT V&V AUTOMOTIVE MACHINE FISHKILL NY. car went 10.49@128 1.51 60ft out of the box. with full 4in exaust altinator, 80lb battery car went 10.50@127 1.47 60ft 6.70@102 8th mile at 3470lbs, nice street car!
quickd100
« Reply #73 on: March 01, 2008, 06:41:34 PM »
I'll throw a curve ball at you guys. The truck in my signature, with the $300 440 in it, it ran a best of 1.595-60ft., 7.621-1/8, and 12.19@105.88-1/4. The truck weighed 3550 and ran 4.56 gears and had a 38.5 square foot frontal area. (lot of air to push down the track)
  Fast forward to now, new motor, new rearend, rollbar. The engine specs;
528 hemi, cast iron mega block, cast iron heads, SS valves, GOOD valve job, ports just cleaned up. 10.5-1, cam is the old MP 614/598 272/274@.050, 104 centerline installed @102. Deep 12 quart pan, milodon duel line system, tray with scrapper. JE custom pistons with .990 pins, Manley sportsmaster 6.965 rods, bobweight, a portly 2642. ATI dampner, V series bearings, Cloyes hexajust, SmithBros pushrods, Comp cams springs&retainers with Manley lashcaps. Weiand tunnel ram with 2 900+cfm modded thermoquads and ram air,  2-1/8"x34"x3-1/2 equal length headers, 18" collectors, 5000 stall, 4.56 dana with spool, caltracks and 10"x 30" slicks. I haven't weight the pig yet but I estimate it at 3800 lbs. I've been shifting it at 7000 and it hasn't hit it's hp peak yet.
  So guys, what are your guesses, what will it run? Dave
maxwedgedart
« Reply #74 on: March 01, 2008, 09:58:30 PM »
hey, quick 100 putting the hemi in is only about 100lbs heavyer then the 440 your truck should run about 11.20@116 in 1/4.
quickd100
« Reply #75 on: March 02, 2008, 10:35:24 AM »
MWD; I believe if it doesn't run into the 10's there's something broke, but maybe I'm over optimistic. The 440 with just some of the old MP recs bolted on exceded the MP predictions. Dave hammer
68_GSS
« Reply #76 on: March 02, 2008, 02:05:08 PM »
QuickD, I guess the mid tens.  Just think what that Hemi would do in an A-body.   Whew
quickd100
« Reply #77 on: March 02, 2008, 04:46:04 PM »
 That's half the fun, nobody expects much from an old truck. Nobody expects to find a stroker hemi under the hood. Dave 4 speed
maxwedgedart
« Reply #78 on: March 03, 2008, 07:19:49 PM »
hey quick  that hemi  you built looking at the specs. i do not think it will even make 600hp and the camshaft is the wrong specs. for that hemi. but good luck with it with spray maybe 10s, but thats what we mopar enthusiasts do what ever it takes to go faster! thats the fun of it right.
maxwedgedart
« Reply #79 on: March 03, 2008, 07:34:16 PM »
hey 68 gss, that hemi in an A-body would not even come close to my 68 with the maxwedge 440! and my knuckles are not suffering from bleeding hemi knuckles! thats a good thing.
quickd100
« Reply #80 on: March 03, 2008, 09:39:39 PM »
  I'm not going to say you're wrong until it's been down the strip on a full pass. The cam though is the same cam that the old MP recs recomended for 426 ci hemi all the way to 10 flat. Granted I've only got 10.5-1 compression but I've got 102 more inches, and a better induction system than what they showed in the recs.  I know a guy on the east coast that runs a 528 crate motor with a new crossram, that's the only deviation. The car is a 65 b body at 3500 lbs., he runs 10.20's or 10.30's with it.
  I guess time will tell, I can't tell you much about 1st or 2nd gear as anything past light throttle in those 2 gears results in instant tire smoke. Generally above 60 mph it will hook, the top of 2nd gear and high gear are brutal. Dave
maxwedgedart
« Reply #81 on: March 04, 2008, 07:43:47 PM »
hey, quickd do not get me wrong i think its cool as hell your truck with a hemi, i also like to be different but as a realist just to go 10.90 at 3700lbs you need a min.565hp to the wheels and at 3800lbs you need about 580hp to the wheels and 650hp at flywheel thats not as easy as you think. and you said 1st and 2nd gear half throttle breaks the tires loose, so that to slows you down so you have to figure out how to get the truck to hook! you need a good 60ft time need to hook and book. shifting at 7000 or higher your not going to get longgivity out of it you should dyno it so you know trk curve and at what rpm your max and averge hp is at. to get your converter right for the truck. you might find your self shifting at lower rpm to stay in peak hp and trk range all the way down the track. these are things you need to think about i know i am 45 and it did not come to me over night. one more thing your said the motor was 10-5-1 comp, mite want to try to come up 1 more comp point  11.5-1 is good for a healthy street hemi. "keep truckin'
quickd100
« Reply #82 on: March 04, 2008, 08:58:32 PM »
No I'm not trying to bust your chops and I've taken no offence, I'm glad to get your input. Maybe I should back up a bit. The truck hooks better than a lot of cars at the strip, it's high center of gravity really helps tranfer the weight to the rear wheels on launch. With the old 440 it had 67% of the weight over the front axle, even with that much weight over the front it still picked the front off the ground about 8" leaving the line. When I talked about it smok'in the tires that was with the street truck radials that are on it. 265/75R15's. You bolt on a set of slicks and get to the strip and it hooks like glue.
  Anyway, time will tell, I'll let you guys know, good or bad how it turns out. Dave 4 speed
maxwedgedart
« Reply #83 on: March 04, 2008, 10:14:44 PM »
hey quickd, ok caltracks is good transfer is must, you really only need about 550 to the wheels at 3650lbs  to go 10.90s at about 123 or 4 even 3700lbs at 575hp 10.80s @ about 125.  i think thats possible if truck hooks like you say you only need to make that horsepower to the wheels stay with it let us know and if i can help you in any way just ask!     RICK!
Dartsport
« Reply #84 on: March 05, 2008, 06:58:25 AM »
Could we stay to Topic, and keep the Race car specs here, Only.    Thanks.
maxwedgedart
« Reply #85 on: March 05, 2008, 06:13:00 PM »
hey dartsport, I HERE YA!
67 r/t muscle
« Reply #86 on: March 09, 2008, 10:05:06 AM »
mines not finished hope to be done by may
472 hemi going to look like 70's pro stock
hemi  street car 10.76@ 125.29 pump gas 3800.lbs.
67 r/t muscle
« Reply #87 on: March 09, 2008, 10:06:13 AM »
another
67 r/t muscle
« Reply #88 on: March 09, 2008, 10:08:12 AM »
one more
certified to 8.50
waynes68cuda
« Reply #89 on: March 11, 2008, 06:48:02 PM »
 1968 barracuda
451 stroker ,  727 trans, 8 3/4 rear end with 410 gears,   2 stage nos,  total 450 shot,  8.30 thousand ft
  with mt 28 12.50  15  slicks,
Pages: 1 2 [3] 4 Go Up Print
