Topic: Losing brake pressure (Read 188 times)
500"Dart
More Ordered Power At Request
I Did the 73 up swap on a 65 dart,turn the steering wheel all the way to the lock position either left or right and the pedal goes to the floor....the brakes work fine with the wheel straight.Any Ideas?
Thanks
70 340 Duster 72 Roadrunner 66 Satellite 67 Coronet RT 81 Mirada 03 Bagged Quad Hemi Ram 70 318 Dart Swinger soon to be a 500" BB 65 Dart GT
jeffmrfixit
all throttle no bottle
sounds like mabe a bad master cylander?
1954 plymouth plaza 1969 dodge dart 1968 chevy nova
65DartGT
Are they power or manual brakes? If they are power brakes, do you have a check valve in the vacuum line going to the booster? If not or the valve is bad the change in idle when you load the PS pump up could be affecting the vacuum to the booster and causing it to actully pull the pedal down. Hope this helps.
sunsetdart
If you are losing the pedal when you turn the wheel, you may be crimping one of the lines.
Midnight Special
I recently was losing pressure with the line loc engaged. Check the upper brass fitting on top of the prop valve mine was loose and seeping. Tightened 'er up---solved the problem...for me at least.
The MIDNIGHT SPECIAL RACING FamilyWichita Kansas AreaNHRA/SFI Tech InspectorNHRA Division V
