August 21, 2008, 06:35:05 PM
| | |-+  9 inch ford rear end in 69 valiant
Author Topic: 9 inch ford rear end in 69 valiant  (Read 643 times)
mopar joe
« on: August 15, 2007, 10:08:03 AM »
     i came across a 1959 ford 9 inch rear end that the spring perches are 43 just like my 69 valiant has any used this rear end in there a body cars this rear is the narrowest one that was made fron 57/59 and should fit pretty good  under my valiant thankyou mopar joe
loiq
Re: 9 inch ford rear end in 69 valiant
« Reply #1 on: August 15, 2007, 01:30:53 PM »
Came out of 67-70 Mustang.
hbear4hw
« Reply #2 on: August 16, 2007, 02:41:41 PM »
 nitrous     I used a 1957 ford in a 1972 dart swinger with a 440. The narrowest 9 inch was in a 1957 ford Rancharo or sedan
delivery, they are also so close on the spring perch location that it will work without moving and the pinion offset is also very
close. So this is a very good swap.
Capt Jack
« Reply #3 on: August 16, 2007, 02:45:27 PM »
hmm...are the perches the same distance etc?  a friend has an old bomber mustang in his yard he's parting out.  chances are good I could get it for next to nada.
a pirates life for me
7173Duster
« Reply #4 on: August 16, 2007, 05:13:20 PM »
I had an old 9" that was 50's vintage the case had a smooth round back and the pig did not have a fill plug in it, I think it's called a war case.  Anyhow, the pinion offset was about 1.5-1.75 inches off to the driver's side from where it should have been.  I looked at it and took it back out, it's now bolted under my friends 68 mustang.  For around $500 I had moser narrow a housing, new axles, bearings, studs, retainers etc and everything lines up correctly.  On small Ford u-joints I ran 10.75 with a 3300 pound car and they didn't break.  I would think the dog track on the driveshaft would cause premature wear or breakage of the u-joint.
All that being said, in a street car it would probably wouldn't hurt anything, for a race car I wouldn't/didn't do it.
loiq
« Reply #5 on: August 16, 2007, 07:25:22 PM »
Almost exact. It's a little wide though, 59.25 inches, but I used a plumb bob and measured it out and a 10-inch rim with 7.5-inch backspace should work - that's giving it an inch on either side, too. Weld makes them with that backspace. Might look funny though. Dunno
If you can find one, the 65-66 Mustang's were narrower. Most of them had 8-inchers though.
dustymopar
moparuk.com
« Reply #6 on: August 20, 2007, 03:29:14 AM »
Hi Have exactly that on my A Bod. Currently use 8.5" Welds with 5.5" bs, and looks fine. Gonna inboard and fit 10" Welds sometime in the future - shouldn't loo any different other than more rubber underneath.....
Dustymopar (UK) - 1971 383 Plymouth Duster
I tried everthing else, but speed is the only answer
7173Duster
« Reply #7 on: August 21, 2007, 01:22:22 PM »
I'm not trying to steal this thread, but last night I found a 69 mustang parts car for sale and I am trying to figure out a good price for it.  How much is the 8" worth to anyone here trying this swap?
Thanks.
loiq
« Reply #8 on: August 21, 2007, 02:45:31 PM »
Personally, I wouldn't pay anything for an 8-inch Ford rear.
« Reply #9 on: August 25, 2007, 06:02:50 PM »
Pssssstt! Dustymopar, I think somebody swiped you gas tank, Bud.   Cool
dustymopar
moparuk.com
« Reply #10 on: August 28, 2007, 04:07:47 AM »
Hey Bud, you are right Shocked Need to get out of this neighbourhood Grin
