August 21, 2008, 06:39:08 PM
| | |-+  Upper door moldings
Author Topic: Upper door moldings  (Read 127 times)
nothingbutdarts
Upper door moldings
« on: August 15, 2007, 10:37:14 PM »
I have the upper door moldings pulled off my 69, they screw into the body above the windows. I was wondering if anybody knew what a guy could use to replace the foam seal, (that would be just like the factory foam) it goes between the molding and the body?
69 Swinger 340
Soon to be 69 426 Dart
80 Crew Cab gas hawg
01 DIESEL Hauler
   Bailey, Colorado
gt
Re: Upper door moldings
« Reply #1 on: August 16, 2007, 12:15:39 PM »
It was a while ago, but if I remember correctly I used a roll of "truck cap sealer". It is a roll of 1"wide foam that sticks on one side only and has wax paper on the other that you peel off. It is about 1/8" thick and compresses very easily but returns when pressure is removed.
Hope this helps
gt
Finally done. 440, 727, 8 3/4...
