January 08, 2009, 12:55:55 AM
| | |-+  Torsion bars
Author Topic: Torsion bars  (Read 611 times)
wedgerulesstreet
Torsion bars
« on: August 20, 2007, 10:39:37 PM »
Hey,i am thinking about using p5249154, torsion bars which are for 1/4 or 1/2 mile circle track racing. Can i use these for regular driving around town? They are much cheaper than most other torsion bar sets. I have a 67 dodge dart with a 400 in it.Is it ok to use these bars , what do u guys think ?
Re: Torsion bars
« Reply #1 on: August 20, 2007, 11:48:38 PM »
you CAN use them for the street but its highly unrecommended, these bars are very stiff, basically eliminating any suspention movement, with a bb i would use a 1.04 at the very most, that will give you nothing but street driving or handling, no weight transfer to the rear
wedgerulesstreet
Re: Torsion bars
« Reply #2 on: August 21, 2007, 09:35:13 AM »
Thanks for the info. Are the bars you suggest available thru Dodge dealer still? It seems junk yards are in short supply on any Dart parts for big blocks. I see you are doing the 400 conversion. Nice. Aluminum haeds will keep the weight down. Also cash in the wallet!
karfixer
Re: Torsion bars
« Reply #3 on: August 28, 2007, 07:12:14 PM »
Check out www.firmfeel.com they have tooled up for their own t-bars, and still carry some of the MP bars. HTH, Steve
Re: Torsion bars
« Reply #4 on: August 28, 2007, 08:29:49 PM »
i would also strongly advise not buying used torsion bars, because not only are they much softer than they were from the factory but they are also alot more inconsistent,
375InStroke
Re: Torsion bars
« Reply #5 on: August 31, 2007, 03:31:29 AM »
How does a torsion bar get softer over time?  Doesn't steel get harder when it is flexed?
Re: Torsion bars
« Reply #6 on: August 31, 2007, 11:09:42 AM »
Spring steel gets weaker. I have bought used bars with good results, but the price better be right. You won't find them (heavy duty torsion bars) in a wrecking yard, though. Alan has the 1.14" bars in his Barracuda (383/4sp) and for the short time he drove it he liked them.
wedgerulesstreet
Re: Torsion bars
« Reply #7 on: October 07, 2007, 01:07:31 PM »
I got a set of bars but no luck getting the old ones out. I feel like taking a torch to them! Only problem is if I cannot get these out, will I get new ones in? Am I overlooking something? I have tried the lock plyers and ball peen hammer. No luck! Gangster
Re: Torsion bars
« Reply #8 on: October 07, 2007, 02:12:47 PM »
Have you loosened the adjuster bolt completely and removed the retaining clip at the rear of the bar? If so, then a lifetime of corrosion has them stuck. If you are going to scrap them, cut them.
*DB*
Re: Torsion bars
« Reply #9 on: October 07, 2007, 04:57:53 PM »
You can also try removing the lower control arm pivot nut & forward control arm nut at the K-frame, then prying the lower control arm back, pushing the T-bar out. That's how I usually do it, & only one time did I come across a bar that wouldn't come out (& a saws-all fixed that), when parting out about 20 cars some 20 years ago.
Re: Torsion bars
« Reply #10 on: October 07, 2007, 07:13:38 PM »
we just put two sets of the biggest vice grips we could get on their, next to each other and got a 5 lb sledge, if that wont take it out, torch it, make sure you take the adjuster bolt out like everyone else has said
GON_RACIN
Happiness is a warm gun.
Re: Torsion bars
« Reply #11 on: October 07, 2007, 07:23:57 PM »
 agree  Thats how I did my last set that didnt want to budge.
wedgerulesstreet
Re: Torsion bars
« Reply #12 on: October 07, 2007, 08:37:59 PM »
HEY THANKS EVERYONE. I WILL CUT THEM AS I DID LOOSEN AND NO JOY. LOOSENING ARM ALSO GOOD IDEA HOWEVER EVERYTHING IS SO OLD I AM AFRAID I WILL DESTROY HALF OF IT TAKING IT APART. THEN I WILL BE LOOKING FOR REPLACEMENT PARTS TILL I AM REALLY OLD AND COMPLETELY DECREPID. I NOW APRECIATE ANY MACHINE THAT HAS BEEN FULLY WORKED TO NEW CONDITION!
