Topic: rear disc brake swaps. does it change yor backspacing? (Read 466 times)
Dodgenut64
this is probably a silly question, but will your backspacing change when you switch from drums to discs? or is it the same? ???thanks
Tom1951
No it won't, the disc rotor is the same thickness at the axle connection.
"73 Dart Sport, 11.5 to 1, 446, Racer Brown STX20, Eddy's, M1 single plane, 850 Mighty Demon, TTI's and soon to be installed a AlterKation... τΏτ
moparteacher
Dodgenut. I replaced my factory drum brake set-up on my Roadrunner with Wilwood rotors and calipers. The set cost $425.00. The rotor is thicker than the drum and moved my wheels out approx. 3/8 of an inch. or so. Hope this helps.
Moparteacher
Moparteacher
spudsdude
?? -- The set cost $425.00
Do you have any more information on that kit? The ones i've been looking at started at $650+
Thanks!! Jim
moparteacher
I purchased both front and rear from Hot Rod Heaven. They sent me a free porportioning( ???spelling?) valve, and three quarts of wilwood fluid DOT 5. Check for a discount code on the web site before placing an order. I received front and rear drilled rotors, front lines (steel braided), valve, fluid, shipped free for under a grand and that was after the additional cost of drilled rotors. Keep in mind that these (drilled, non-vented) rotors are recommended for light vehicles. The rotors and set-ups are common on Stock Eliminator cars and some Super Stock or slower bracket cars; I don't think they would be a good idea for street applications, high speeds (125mph plus) and heavier cars.
Moparteacher
Moparteacher
moparteacher
Just checked and they are $539.95. I ordered them about 8 months ago. This set does not have the parking brake set-up. They still offer a coupon for shipping (-$20.00) or free shipping plus the previously mentioned parts for front and rear orders. Check the coupon folder first.
Moparteacher
Moparteacher
moparteacher
Aerospace Components offers a rear disc kit for $456.00. Someone also sells a caliper adapter on e-bay to put G.M calipers on your mopar. You can also purchase a caliper bracket that clamps onto the housing tube for a G.M. caliper ( I think) from AFCO and other roundy-round parts suppliers. Check the circle track suppliers, they have all kinds of goodies for control arms, caliper brackets, shocks, adapter this and adapter that type stuff.
Moparteacher
Moparteacher
enigma
Ciscodog
Ummm... YES it changes the required backspacing. The hat is 1/2" thick, so that's going to space your wheels out 1/2" on each side. The drum flange is only like 1/8" thick.
Carter
sycboi
My Wilwood rear brakes are only 1/4" thick...not too far off from a drum thickness at that point. Maybe an 1/8" thicker?
Ciscodog
Wierd - I have the Wilwood drag kit and the hats are 1/2". You aren't measuring the rotor are you?
sycboi
Well, I have the Wilwood Prostreet 12.19" rear discs. It is exactly a 1/4" where it sets on the axle face. It spaces the wheel out exactly a 1/4" from the axle face. The directions even have it measured at 1/4". It's a 1/4"
Ciscodog
Wow - that's a big difference. That makes it a bitch to plan for eh? Wonder why the drag kit (11 1/2" rotors) has a thicker hat than the bigger 12.19" rotor? Anbody? Bueler? Bueler?
