BIG DOG
I read on another post someone was asking about clearancing passenger side shock tower is this only for the Hemi or the 440 also .Or are there some areas that can/should be massaged a little on the inner fender to help with clearance?
acpat
clearance it, clearance it, clearance it. My buddies 68 dart with 440/tti headers baked the paint off the inner fenderwell. It will not rub but it will cook off the paint if you don't
Online
440 with b-body HP manifolds WILL contact the inner fenderwell at some point in time. The best way to clearance is to take a large hammer and place it against the metal and hit that hammer with another large (3lb sledge works well) hammer. This produces a much cleaner look than what the factory did on the hemi cars.
acpat
 do it if not you will regret not doing it. If you do it as posted above you will have to look very hard to tell it has been done
BIG DOG
OK SO where then do I do this on the bumps where the upper control arms attach or the whole area or more up top near the top of the shock tower???
Online
It's the upper edge. I'll see if I can get pics of Jeff's Dart.
BIG DOG
That would be great Jim as I'm close to doing this.
Online
Look closely at the area next to the center ports on the manifold. I laid that over a little.
BIG DOG
Wow!! Jim is that one that hasn't been clearanced?It sure is close now.So what am I trying to do pound the top of the shock tower over because the inner fender is tight to the shock tower mount now .And how much does it need to go? Am I pounding between my fingers or over outside of that where the finger and pen point where there is no tower behind
doug 371
what brand is that black epoxy ur using big dog?
BIG DOG
doug 371 it's SPI it's great stuff sticks like sssssst to a shingle!
Online
It's more to the rear of the shock. There's actually quite a bit of space between the fenderwell and shock tower. What happens is the motor mounts sag (DC k-member with 74-78 factory mounts) and cause the clearance to go away. Next time that car comes apart it's getting poly mounts, but then we may have to relocate the master cylinder.
BIG DOG
So I'm going to massage it in where my finger is pointing in theis area?How far in 1/2 " ?? Thanks!
MVRCorp
Here's some pics Bill sent me prior to me opting for an Alterkation.
MVRCorp
After going with Bill's alterkation this is what I did.
Online
Yes, where your finger is and about 1/2" is good.
BIG DOG
Hard to tell from the pics with the engines in there.I didn't really want to get into cutting the tower and stuff so....... I did a little massaging with the hammer today going to be ok .Hate to pound away on a good part of the car!!
BIG DOG
No replies does that mean it's wrong  Hey I got no replies to say that's right or wrong .So I'm kinda wondering if I misunderstood where I was suppose to hammer  ( and nobody's saying anything).I didn't want to get into cutting the tower and stuff and from the input this is what I understood it needed.
abqdart
from what I can tell the whole area needs to be clearanced. I have fenderwell headers on mine and had to make slight room right at the shock support. maybe 1/4 inch...didnt require any cutting although I think it would look better if I took the time to REALLY make it look good. My .02
Rio Rancho N.M 87144
Mopartist
MVRCorp ; Thats a pretty awesome alteration. I think thats what I'll do as well when I buy my front end. looks great!
illfish
You know BIG DOG, that doesn't look half bad. With a little sanding and mud it would be great. I'm not sure it the center will hit anything or not.
Online
I think the area by the shock tower should go in about 1/2 inch or so. then I think there'll be plenty of room.
Pro Street dart
Did you guys see that Indy Cylinder head has new HEMI valve cover that are relieved for shock tower clearance? What I great idea. Not that I need them.
I have a 440 in a '68 w/ TTI headers. I run a Schumacher Torque Arm and it holds the header from contacting the shock tower. NO contact as long as it's re-adjusted periodically.
Pro Street dart
I have a 440 in a '68 w/ TTI headers. I run a Schumacher Torque Arm and it holds the header from contacting the shock tower. No contact as long as it's re-adjusted periodically.
Jim, please delete this post
