Topic: 4.5" lug pattern on a 72 swinger (Read 339 times)
72 dart
I have a 72 swinger with front disc brakes and 4" bolt pattern. What do i need to do inorder to change up to the 4.5" bolt pattern. Can I use the same spindles and control arms and just change up the rotors?   ?
abodyjoe
i think there may be a kit out there to just change the rotors but not 100% sure... sacrid bird maybe
RoachRunner
sacrid bird maybe I think he means Scarebird  I just strolled through their site, but I didn't see it. I have seen the stock rotors redrilled, guy had Moser do them. That's probably the way I'll go.
 D'oh! Stupid brain....
robx4406
Get a conversion kit that is from a 73-76 a-body.
You'll need the upper control arms as well because the late model A's have a bigger ball joint than 72 and earlier.
I may have a kit with upper arms available.
Scarebird might have something, but you already have disc on the car.
farmington
Get the upper control arms, spindles, calipers, rotors, master cylinder, and the brake distribution block all from the same car. 73-76 A body. If its a 73-76 and it has front disc brakes it will be the large bolt pattern.
When in doubt, Whip it out!
abodyjoe
sacrid bird maybe I think he means Scarebird  I just strolled through their site, but I didn't see it. I have seen the stock rotors redrilled, guy had Moser do them. That's probably the way I'll go.  ,.. yea that it.. i thought they had a kit to change from drums to disc and figured maybe they would have the larger bolt pattern kit too... oh well worth a try
Online
Redrilling those rotor/hubs is not really an option due to the gaps between the rotor and hub. SSBC has a rotor with spacer that I believe is a 65-67 Mustang rotor (same bearings AND caliper).
Dust 1
I have a 72 swinger with front disc brakes and 4" bolt pattern. What do i need to do inorder to change up to the 4.5" bolt pattern. Can I use the same spindles and control arms and just change up the rotors?   ? I have the same problem on my 71 Duster, redone it several years ago with parts off a wrecked 71 340 Duster before knowing all the ins and outs. I am hoping that someone comes up with a conversion rotor that is 4.5" so I won't have to go the whole 73-76 conversion since I have already replaced all of the front end with brand new parts. Geez, you would think someone would have invented one by now.
