Topic: Housing (Read 264 times)
512Stroker
Housing
« on: September 06, 2007, 04:42:46 PM » |
Would it be wise to place a drain plug and fill area on the housing? If so, is this something fairly easy to do?
 There is no replacement for displacement... Currently 1970 Dart Swinger 318/904 (Work in progress)  Soon to be 383--496/727, 8 3/4
Re: Housing
« Reply #1 on: September 06, 2007, 04:54:01 PM » |
There is a fill plug on the carrier. I have a drain on my 8 3/4. It certainly makes the job a ton neater.
512Stroker
Re: Housing
« Reply #2 on: September 06, 2007, 05:08:10 PM » |
There is? I just tore it out of a Newport and have not looked it over. But to make things easier I can weld in a bung and add a plug? I think that is the correct terminology...
Re: Housing
« Reply #3 on: September 06, 2007, 05:59:24 PM » |
Make it real easy on yourself and put the plug right in line with your ring gear and make it pretty big so you can also inspect the condition of the gear through it.
70 Dustpan
Re: Housing
« Reply #4 on: September 06, 2007, 06:21:16 PM » |
The fill hole is in the 3rd member, not the housing.
Hey, I'm a God again!
Re: Housing
« Reply #5 on: September 06, 2007, 08:02:24 PM » |
I told him that. He still wants to put a fill hole in the housing.
512Stroker
Re: Housing
« Reply #6 on: September 06, 2007, 08:27:08 PM » |
I take it multiple fill holes is not needed/unnecassary???
4spdfury
Re: Housing
« Reply #7 on: September 07, 2007, 12:31:38 AM » |
we always put a filler in the housing and a drain. it makes it alot easier all around
