January 08, 2009, 04:27:31 AM
| | |-+  Torsion Bar removal
Author Topic: Torsion Bar removal  (Read 219 times)
smallbigblock
Torsion Bar removal
« on: September 07, 2007, 11:20:06 AM »
I'm new here so pardon my greenness.  I'm having a little trouble removing one of my torsion bars on my 67 Dart.   I have done all the thing that you are suppose to do to relieve the pressure on the bar it's self, but I just can't beat it out.  I'm starting to get a little concerned about the Lwr Control arm pivot bolt damaging the K-frame.  Any help with tips or tricks will be greatly appreciated
I should have left it alone
Re: Torsion Bar removal
« Reply #1 on: September 07, 2007, 11:23:40 AM »
There is a tool available or you can make one (something to clamp to the bar that you can hit with a hammer). I am also assuming you have removed the retaining clip at the rear of the bar.
If you are replacing the bars they can also be cut in half. I have been known to remove the k-member first, too.
smallbigblock
« Reply #2 on: September 07, 2007, 11:34:06 AM »
Yes I built my own tool and did remove the clips.  Cutting was one thing I was mulling over but wasn't sure of the Consequences.  I am using new bars and I have different  control arms.  So maybe cutting is the right way to go?
smallbigblock
« Reply #3 on: September 07, 2007, 02:22:38 PM »
Well Thanks for all the info, I finally got it off.  Just had to hit it a little harder and a little longer.
Tejas
Grand Prairie Texas
« Reply #4 on: September 07, 2007, 02:24:53 PM »
Well I finally got it off.  Just had to hit it a little harder and a little longer.
That's what she said!  lol
'71 Duster, just getting started...
« Reply #5 on: September 10, 2007, 01:34:56 AM »
Future reference: I use a 4X4 about 8ft long. Some nice sofe pine and I use it as a battering ram against the lower control arm. Works everytime and since it is pine it chips and falls away without bending up the LCA. But as it is a heavy piece of wood it tends to win.
