Topic: What will strip off undercoating (Read 727 times)
sperrydan
What will strip off undercoating. Never tried before but need to get it off the back side of my front fenders and everything with undercoating realy.
eldubb440
elbow grease
eldubb440
but seriously folks.......name yer poison. i prefer paint stripper
Mopartist
Brake cleaner turns it to liquid if soaked
Duster440
Propane torch to soften, putty knife to scrape, Goof-off (or most solvents) to remove residue.
rjsjea
I had mine sandblasted when the body was done.....worked great
Demon:,6.1HEMI, AlterK,Tri4link,custom cage,pro-touring-built for the curves....not much hasnt been modified
Cpt Panzer
GTS225
Ummmm....I suggest a heat gun, rather than something with an open flame. Doing mine that way, and the "residue" comes right off with silica sand at high velocity.
Roger
Duster440
If you're more comfortable with a heat gun and sandblasting, that's fine. The factory undercoat isn't that volatile and it takes little to soften it. I even tested an open flame on Goof-Off saturated undercoat. Nothin'. Take appropriate safety precautions.
acpat
putty knife and propane torch.
392dart
putty knife and propane torch then i used laquer thinner to get the rest . Then i sprayed a thin layer of truck bed liner
QK TIME
I just did this a couple months ago. I used a MAPP gas torch and scraped it. Then went over it with a grinder with a bristle disc on it. Time consuming but not that hard. Have fun.
sperrydan
 I was hoping you guys had a magical way to do this. Arrrrrrrrrrrrrrggg  You guys are going to make me WORK!!!! Thanks
 I was hoping you guys had a magical way to do this. Arrrrrrrrrrrrrrggg  You guys are going to make me WORK!!!! Thanks The magical way is your checkbook or credit card.  Pay someone else to do it. If I had to do it again, I would pay a sandblaster to do it for me. That was one messy, dirty job. Hey, here is an idea, call Mike Rowe!
sperrydan
The magical way is your checkbook or credit card.  Pay someone else to do it. If I had to do it again, I would pay a sandblaster to do it for me. That was one messy, dirty job. Hey, here is an idea, call Mike Rowe! Thats funny Im watching Dirty Jobs Now.
66sat440
torch,scraper,chisel and a few spare evenings!
thats gonna leave a mark!
sperrydan
I started last night and olny had time from about 30 mins and only got a 2x2 area in the front wheel wells, I was hoping the car would take about 4 years to complet but after doing an easy area to get to ,and only geting a little done. It will take 4 years just to do this.  , It will payoff in the end.....I hope. Or am i just know geting sucked into the Blackhole known as restoration
sperrydan
How much is something like that. I was looking for some rope to hang myself last night.
75Dart440
High detergent Dextron II transmission fluid worked on mine. Everywhere the trans fluid had leaked on the undercarriage, it had softened the factory undercoating to the point that it would easily come off with a steel putty knife. Don't know if it would work fast enough if you just applied it by hand.
RBdart
I used a citrus based HOUSE HOLD type paint stripper and it worked great! Never even touched the factory paint below, softened the under coating and allowed 90% to scraped off with a putty knife. I then used mineral spirits and steel wool to clean off any residue and to get into tight areas. Good luck, no matter what you do it's ALOT of work.
digler
DRIVE LIKE LIGHTNING CRASH LIKE THUNDER!!!!
the only way is a propane torch and scraper except i used map gas sold right next to the propane cause it burns hotter then once all scraped off you use a 3m style scotvh brite pad and kerosene and a little elbo grease , then sand blast and put in sealer like ppg dp50lf a great epoxy primer that i use and trust very much to prevent corrosion
good luck the job sucks and wear a resperator as undercoating produces nasty fumes I know if done 3 cars like this now.
eldubb440
a hundred ways to remove undercoat, and they all suck
 ...except for paying someone else to do it.
eldubb440
come on now......you know better...... IF YA WANT SOMETHING DONE RITE, YA GOTTA DO IT YOURSELF!!!
lucasdart
I spoke to the sandblaster over the weekend, he was done with the sandblasting, looks awesome, there is no way that a putty knife and wire wheel could have done the same. Another thing is that it will find and clean all the rust out too. He said for the blasting he was around $700, he also did the engine compartment and wheelwells front and back. Some may think it seems like alot, but how much is every weekend and night for 3 months worth? I'm pretty happy with the guy so far.
