Topic: Lower ball joints (Read 864 times)
Darren
Doug on closer inspection look what I found
Darren
Thanks for your help, The guy who had the car before me made a sleeve to use the small ball joints with the big joint spindles. One more question. tomorrow I am looking at a set of upper control arms, I want to know if the big and small upper ball joints fit into the same hole in the control arm? Thanks
big joint requires the bigger control arm...glad u got it figured out...doug
Darren
So I need upper control arms off 73 and up a body? What a bout B body? Thanks
they will have to be 73 up a body with big joints...b body doesnt work...some 73-76 cars with 6 cyl still got small bolt pattern so be careful
Darren
Thanks doug for all your help.
