July 05, 2008, 07:11:32 PM
| | |-+  '69 DART REMOVE A/C EVAP COIL AND HEATER BOX
Author Topic: '69 DART REMOVE A/C EVAP COIL AND HEATER BOX  (Read 208 times)
ojaidart
11.61 @ 120
« on: September 11, 2007, 08:30:00 PM »
I was able to get my dash pad out last weekend.  Now I need to remove the A/C coil and heater core from under the dash.  I have no idea how the entire assembly is bolted to the car.  I am guessing the bolts sticking thru the firewall held by nuts/washers are the key to removing the entire assembly under the dash.  Any tips would be really helpfull.  Thanks in advance
LOOK STOCK BUT SWING A BIG ARM
375InStroke
Re: '69 DART REMOVE A/C EVAP COIL AND HEATER BOX
« Reply #1 on: September 12, 2007, 03:20:57 AM »
Inside the passenger vent door is a J bolt that goes up to the cowl.
ojaidart
11.61 @ 120
« Reply #2 on: September 12, 2007, 11:00:01 AM »
I never saw the J bolt until you mentioned it.  Thanks.  Any other hidden bolts?
