September 07, 2008, 07:44:29 AM
| | |-+  Front Suspension Setting
Author Topic: Front Suspension Setting  (Read 271 times)
Merrimack NH
strange246 strange2462000
« on: February 11, 2006, 03:39:19 PM »
Anyone know how much to crank up the torsion bars before I try to set it on the ground on it's wheels? To set it per the service manual it has to be sitting on the ground, but how much should I crank up the adjusters before even sitting on the ground so it doesnt bottom out immediatly? the motor is out but I want to be able to sit the front end down on it's wheels so I can move it around in the garage....
Dr. Hunter S. Thompson
jet-taz
Re: Front Suspension Setting
« Reply #1 on: February 11, 2006, 05:07:45 PM »
i bottom them out and count the turns on the adjusters then go 1/2 way.
Wisconsin
« Reply #2 on: February 11, 2006, 07:26:21 PM »
With the engine out, you should only need a few turns. Especially if you have decent size torsion bars. You'll have to crank them up after the engine's in of course.
Merrimack NH
« Reply #3 on: February 12, 2006, 02:08:33 AM »
 thank you they're the .920's....
« Reply #4 on: February 12, 2006, 02:27:42 AM »
I usually set the head of the bolt even with the bottom of the control arm. They should be set the same. Make sure you give it a good bounce to settle it when you set it on the ground.
Merrimack NH
« Reply #5 on: February 12, 2006, 02:29:55 AM »
Thats without the motor correct?
« Reply #6 on: February 12, 2006, 02:31:51 AM »
Ryan, it doesn't matter whether the negine is out or not. It'll just sit higher without the weight. If you put the adjuster there you shouldn't have any problems when you add the drivetrain.
Merrimack NH
« Reply #7 on: February 12, 2006, 02:33:39 AM »
Thanks Jim...
« Reply #8 on: February 12, 2006, 08:32:20 AM »
  yea thats how i usually how i do it also..
