October 10, 2008, 03:35:58 PM
| | |-+  How to tell forged (steel) crank from cast crank...Please HELP! New pictures...
Author Topic: How to tell forged (steel) crank from cast crank...Please HELP! New pictures...  (Read 845 times)
daniel_depetro
Marquette, MI 49855 (Upper Peninsula)
daniel_depetro
« on: September 13, 2007, 09:52:27 PM »
I bought a remanufactured 400 engine (long block) that is suppose to have a forged steel crank in it. How can I tell if the crank in my engine is forged or if it is just the standard cast crank?
I didn't notice any numbers/markings on the ends of the crank but being installed the rest is hard to see.
1974 Dart Sport, 1974 Duster, 1971 Barracuda, 1974 'Cuda, 1970 Challenger R/T-SE, 1970 Challenger 340, 1971 Challenger 340, 1968 Coronet, 1970 Duster 340, 1973 Duster 340, 1971 Demon, 1972 Demon, 1973 Dart Sport 340, 1973 Dart Sport, 1977 Volare, 1971 Dart, 1970 Dart
451 valiant
Ontario, Canada
Re: How to tell forged (steel) crank from cast crank
« Reply #1 on: September 13, 2007, 10:14:59 PM »
The harmonic balancer will have a weight on it on the front if it's a cast crank. A steel crank does not. I didn't think 400's came with  steel cranks from the factory, not sure though.
daniel_depetro
daniel_depetro
« Reply #2 on: September 13, 2007, 11:16:48 PM »
400s all came with cast cranks from everything I have read, however this one is suppose to have a steel crank in it. I just wanted to make sure. It is a long block thus there is no balancer on it.
Long Island, NY
« Reply #3 on: September 13, 2007, 11:18:51 PM »
A 400 could have a 383 crank in it, then it could have a forged crank.
Dcuda69
WI
« Reply #4 on: September 13, 2007, 11:26:08 PM »
AFAIK all 400's were cast cranks(ext. balance) I beleive 383 forged cranks(internal balance) are a bolt-in. A cast crank will have single "parting line"(from the casting process) and a forged crank will have a wide(looks like 2)parting line. I think you need to find out one way or the other so can purchase the correct balancer! good luck with your project!! 4 speed
sr71mopar
Santa Rosa, CA.
« Reply #5 on: September 13, 2007, 11:47:55 PM »
According to Ma, 400's from 72-3 with 4 speeds should have steel cranks.
Forged and cast are easy to tell apart by looking at them.
ski
« Reply #6 on: September 14, 2007, 12:29:08 AM »
Here's a pic I just took and another I found in my picture folder when I was resizing it.  The crank on the right in the first pic is a cast 318.  The one on the left is a forged 383.  The second pic explains it nicely and is a file photo that someone else took.
oldkimmer
« Reply #7 on: September 14, 2007, 01:27:03 AM »
If it is indeed forged it will have a pilot hole for a manual trans, cast will just have a divet ..............kim............
rigpig
Kissimme, Florida
« Reply #8 on: September 14, 2007, 10:43:04 AM »
Ya'll need to remember the forged cranks on the six pack engines used external balancing.
Bob
70 Duster 440 eddy heads TTi's Dana60
rharveysr
« Reply #9 on: September 14, 2007, 01:37:40 PM »
Quote
  Explain this one to me please!
Rick
rigpig
Kissimme, Florida
« Reply #10 on: September 14, 2007, 02:32:05 PM »
because of the heavy rods used on the 440 sixpack engines they were the only forged cranks to use extenal balancing.
Bob
451 valiant
Ontario, Canada
« Reply #11 on: September 14, 2007, 08:16:43 PM »
Quote
Rick
Here's a link that shows the difference between the balancers.  Down the page shows forged, six pack and cast crank (6pk and cast have the extra weights on the front). hope this helps:
http://www.440source.com/dampers.htm
JohnnyfromChicago
« Reply #12 on: September 16, 2007, 02:34:40 AM »
Sounds like your gonna need to pull the pan to check it against the pictures here to figure out what balancer to keep it from coming apart.
daniel_depetro
daniel_depetro
« Reply #13 on: September 29, 2007, 06:15:48 PM »
OK, there are drilled weight indentations on it and it appears it is a true drilled for a stick crankshaft. I did not see any 'parting lines' on my crank as I rolled the engine upsiode down on the stand (I did not actually spin the rotating assembly). It also has a circled '13' or something stamped on the end like a forged unit should. The cylinders on the right of the picture look like they have the rounded edges on the counter weights like a forged crank should have. Although the cylinders on the left of the picture look like they have sharp edges...
You experts tell me, is this a forged or cast crankshaft?
This is suppose to be a stock 400, how did it end up with a forged crankshaft?
68S
Re: How to tell forged (steel) crank from cast crank...Please HELP! New pictures...
« Reply #14 on: September 29, 2007, 06:36:12 PM »
That looks like a forged crank. Check out the pics Ski posted they should help you make the cast/forged determination.
As far as why the engine might have originally received a steel crank, sr71mopar already posted that for you too
Good luck with the project,
Pat
daniel_depetro
daniel_depetro
« Reply #15 on: September 29, 2007, 06:51:58 PM »
True, but this 400 has a casting date of 7-26-77.
I just wanted to be sure and have a second, third, fourth,... 50th opinion...
268darts
« Reply #16 on: September 29, 2007, 07:06:43 PM »
Did it come out of a motorhome?
daniel_depetro
daniel_depetro
« Reply #17 on: September 29, 2007, 07:19:41 PM »
I have no idea where it is from. It was a 'new' remanufactured long block engine from Fliteline Engine Supply that I paid $325.00 for off of eBay about a month ago. They said it was .030 over and it came with a new Melling M63HP high pressure oil pump. I asked what it was out of and they did not know. They said Challenger/Charger VIN: LP23, N or M so that wasn't much help. It is all fresh so I figured I couldn't get a good junkyard engine for that price, especially with a fresh forged crank that was drilled for a stick (manual tranmission) like they advertised. Heck it is hard to get just the heads redone for what I paid for this engine. Too bad the compression is a sad 8.0:1. It should still make for a fun driver with all of my parts I bought for it.
68S
« Reply #18 on: September 29, 2007, 07:33:32 PM »
To me 77 does seem a bit late to still have the forged crank but I am no expert either.
Seeing as how these cars and their related parts have been around for so long now, you never really know what you might run into. Since your shortblock is a reman piece that crankshaft could very well have come out of a 383 or an original 400 four-speed application but it should not matter to you either way. All that really counts is that you have the good stuff and it looks like for $325 you scored a winner with that motor. The 8:1 compression part needs some help though. You will be seriously limited in cam selection with a low compression ratio like that.
Pat
fasttcars
« Reply #19 on: September 29, 2007, 07:38:27 PM »
it's a forged crank...
440WIP
« Reply #20 on: September 29, 2007, 10:21:12 PM »
 8:1 compression - put a blower on it................
Daryl
Long Island, NY
« Reply #21 on: September 29, 2007, 10:24:26 PM »
Pull it apart and deck the block.
fasttcars
« Reply #22 on: September 29, 2007, 10:28:46 PM »
id also have it properly  balanced ....
abqdart
72 Swinger 394/727/8.75
« Reply #23 on: September 30, 2007, 12:21:15 AM »
T U R B O...........
Rio Rancho N.M 87144
loiq
« Reply #24 on: September 30, 2007, 10:03:26 AM »
Got pics of the tops of the pistons?
daniel_depetro
daniel_depetro
« Reply #25 on: September 30, 2007, 10:58:38 AM »
Nope, it came all assembled: long block (with heads already installed/torqued) I just bought some MP steel shim head gaskets, so I'll be pulling the heads off to switch gaskets. I can get some then.
Steve DeTar
« Reply #26 on: November 15, 2007, 04:58:35 PM »
I'm replying so this can go up to the top again.
Engine by DeTar
Capt Jack
« Reply #27 on: June 30, 2008, 11:14:09 PM »
this thread should be pinned or added to tech.  just helped me out again   Cheers
bbd sign
67 dartgts
Go fast or go Home
« Reply #28 on: July 01, 2008, 07:41:54 AM »
Hello:
Coppied from MOparts.
The 383-440 steel crank bal is on the left and the 400 cast crank is on the right.
Maynard
ksdartguy
« Reply #29 on: July 01, 2008, 09:23:27 AM »
Yes, for what ever reason, It is a Forged Crank  Shocked
Rick
Pages: [1] 2  All Go Up Print
