January 08, 2009, 03:36:37 AM
| | |-+  tach mounting
Author Topic: tach mounting  (Read 848 times)
rscottick
tach mounting
« on: September 19, 2007, 06:23:18 PM »
please post pics of how you mounted your tach. I just bought a 5" tach for my duster and have no idea where to mount it or how. Thanks
Ron
Re: tach mounting
« Reply #1 on: September 19, 2007, 06:33:31 PM »
thats why I got a very small digital one.  I had a 3" analog one on the column but I didnt like the placement or mount (a large steel hose clamp).  now the 2 1/16 digital one with a shiftlight is just behind the shifter on the console using a cheapo bezel I got at a swapmeet.
Re: tach mounting
« Reply #2 on: September 19, 2007, 09:48:56 PM »
73swinger
Blackstock, Ontario
Re: tach mounting
« Reply #3 on: September 19, 2007, 10:33:12 PM »
i opted for the sleeper approach, of course you can still easily see the shift light. but you can't see the tach from outside the car
Re: tach mounting
« Reply #4 on: September 20, 2007, 12:02:18 AM »
i have a custom dash and still put mine on the hump as well,works for me.
farmington
Metro Detroit
Re: tach mounting
« Reply #5 on: September 20, 2007, 12:37:34 AM »
here's mine
When in doubt, Whip it out!
dangerdawg
Re: tach mounting
« Reply #6 on: September 24, 2007, 10:08:19 AM »
here's mine
               i like it, mine is in same place, just a different bracket.
larry408
Re: tach mounting
« Reply #7 on: September 26, 2007, 09:01:29 PM »
I have a small 3 inch tach that is mounted on the drivers a post. It is very easy to see there.
Larry Gathright
1973 Dart Sport
USAF 68-72
NRA Life
drjay0
Re: tach mounting
« Reply #8 on: September 27, 2007, 09:57:35 AM »
Large hose clamp to the column. I like to be able to see my tach and shift light without taking my eyes away from the windshield.
263 Posts on old board. Member since March 2003.
"Where the hell do i go to tell the world my dog died or my gf is in jail or my penguin ran away!" -njsuperbees
jamie_aitken
Re: tach mounting
« Reply #9 on: October 25, 2007, 01:34:18 PM »
Check out www.thecarfarm.com.The bracket slips under dash pad-NO HOLES to drill!!
B-onefan
Wild West Texas
Re: tach mounting
« Reply #10 on: October 25, 2007, 03:02:02 PM »
Here is one I made out of 1"strap and a 3/8 steel tube. I tried to attach, but won't let me. Let me know where I can send it and I will be glad to. File is 786KB.
73 Duster
74 Duster
76Duster
67 Barracuda
68 Barracuda
68 Dart
69 Dart
72 Dart
78 Trail Duster
1999 Ram 1500 Sport QC 4X4
Re: tach mounting
« Reply #11 on: October 25, 2007, 03:06:50 PM »
I have some parts for a mount I thought might lend itself well to a relatively serious sleeper.  I grabbed an old broken Black&Decker snake light for $1 at a swap meet and grabbed the flexible neck from that.  Plan is to mount one end under the dash and the other to the digital tach/shift light.  pull it up to where I can see it when I need it and just push it back under the dash somewhere when its not needed.   maybe wire in a small switch to be able to turn it off when not in use.  might even end up mounting the line lock switch to it as well
pics when I get it mounted.
edit:  B-onefan , so ahead and PM it to me if you can and I'll post it for you
jackie
Re: tach mounting
« Reply #12 on: October 25, 2007, 05:01:08 PM »
here is a bracket that i have used a couple diff. times. i screw it under the lip of the dash, so no holes in the pad. you take the stock tack  bracket off, and slide the tack through it. you can angle it also. it is tight and works good.
rscottick
Re: tach mounting
« Reply #13 on: October 25, 2007, 08:19:19 PM »
B-onefan, you can e-mail it to me at rscottick@comcast.net
dusterdarryl
Re: tach mounting
« Reply #14 on: October 28, 2007, 04:30:36 PM »
Iv gone the hard core approch, since my car started out as a write off my dash was never very easy on the eye, and when I built the cage I wanted the front droping bars as close to the A piller for more room which left a difficult install for the factory dash, since I lived in New Zealand at the time a replacment dash for a left hand drive A body was out of the question, hence the custom dash,
I mounted my tach right in my face because once you stage the car you dont have time to look away to check you rpm's and look back at the tree,
Re: tach mounting
« Reply #15 on: October 29, 2007, 10:57:36 AM »
Quote from: B-onefan
pictures are of a tach mount I made. It is out of 1: strap and 3/8 steel tubing. I will drill 2 holes thru the dash and bolt thru to a 1” strap that runs to the firewall for support. The 2 holes are easily welded up and puttied if needed
posted for B-onefan
440+6Scamp
Re: tach mounting
« Reply #16 on: October 30, 2007, 09:23:32 PM »
Any thoughts on an in-dash tach?  Did any of these cars come w/ a tach on the dash?  I have a '74 scamp and would like to have a tach on the dash but I can't come up w/ a good way to do it.  There's a small unused area to the left of the speedometer that I thought putting one, but I can't seem to find a guage small enough to fit that spot.  Are there any other options?  I'm not planning on racing the car much so I don't really care how small or out of line of sight it is.
Re: tach mounting
« Reply #17 on: October 30, 2007, 09:37:23 PM »
http://www.nextag.com/mini-tachometer/search-html
67 dartgts
Go fast or go Home
Re: tach mounting
« Reply #18 on: October 30, 2007, 10:11:38 PM »
Mounted on pillar post...used a piece of flat stock then welded a piece of 3/4 inch square to flat.  Drilled holes in flat to mount to pillar..made mount for tach  on end of 3/4 tube.
         MAynard
