Topic: Rear Spring Set-ups (Read 234 times)
zpsull01
I'm still very undecided about whether to go with a welded rear suspinsion clip that uses a 4-link, coil-overs, and makes room for up to 15" wide slicks or to just mini tub the rear, move the springs in, and run 10" wide tires on my 72 Duster. I would really like to run a coilover setup with a 4-link without moving the frame rails if I don't go with the clip. I know that RMS makes a nice 4-link setup with coil-overs that is designed specifically for A bodies but is there anything else out there simular that I can compare this to? What are your opinions on this? And what would you do?
