Topic: 71 duster scoops (Read 274 times)
71Mopar
I bought the dual duster scoops for my 71 duster. I need a pattern so I know where to drill the holes. Any help would be appreciated
west
i took a piece of lexan and traced the underside of the scoops marking the bolt holes too,then drill out the mounting holes through the lexan drill one hole from the bottom of the hood(there is a post showing these locations). next put the lexan on top of the hood lining up with the one hole you drilled then mark the rest of mountinng holes through the holes you made in the plastic.
71Mopar
Thats a great idea. Can you measure one of the scoops from where it sits in relation to the hood? If I can found a reference point I will use your idea. Thanks again
drjay0
I have these saved from FABO.com They worked like a charm in helping my brother in law locate the drilling points.
263 Posts on old board. Member since March 2003. "Where the hell do i go to tell the world my dog died or my gf is in jail or my penguin ran away!" -njsuperbees
