Topic: 400 block (Read 503 times)
2815spd
400 block
« on: October 01, 2007, 12:45:09 PM » |
What's the best years for the 400 block? How much hp can one of these take?
2815spd
also are the main sizes the same on a 400 and 440?
BBLM23
No.
Walter 1981 Dodge Aries 451 B1/BS Best 1/4 9.871 at 136.01mph 1969 Dart Swinger 431 B1/BS Best 1/4 10.649 at 126.45mph Racing Pro in street trim. 1981 Plymouth Reliant 400 http://bbdart.com/parts/parts.html
2815spd
I assume the beefier 440 main is better?
BBLM23
I don't think so, some people do. On a 440 the crank journal is larger but that means the main cap is thinner. I would rather have the 400 size crank journal with more meat in the main cap and block.
2815spd
On the after market blocks, are they all the 440 main?
BBLM23
I think so. The caps should be better on an aftermarket block, so less of an issue.
2815spd
I think so. The caps should be better on an aftermarket block, so less of an issue. I'm sending you a pm
speedymopars
KB uses the 440 size mains, and is able to use either early or late bearings (#3 thrust) .
2815spd
Where do find prices and specs for these blocks?
Steve DeTar
The good ones are fairly hard to find. All 383's and 440's have smaller main saddles....except the later 440 blocks cast late in 76 to 79 that end with 630 in the casting number
Engine by DeTar
daniel_depetro
1974 Dart Sport, 1974 Duster, 1971 Barracuda, 1974 'Cuda, 1970 Challenger R/T-SE, 1970 Challenger 340, 1971 Challenger 340, 1968 Coronet, 1970 Duster 340, (x2) 1973 Duster 340, 1971 Demon, 1972 Demon, 1973 Dart Sport 340, 1973 Dart Sport, 1977 Volare, 1971 Dart, 1970 Dart
oldkimmer
The run of the mill 400 block 451 stroker in my buddies old 70 duster ran 10.20s at 3000lbs.............kim.........
R5-P7 project
Hi Friend, I prefer to bore out my 400 mains to 440 size to get better bearing selection. Actually, it's cost effective too; as you would probably (I know I would) align bore the block anyway. Anyway, thats the way I would do it.
dustymopar
moparuk.com
Dustymopar (UK) - 1971 383 Plymouth Duster I tried everthing else, but speed is the only answer
Bearing choices be danged! I'd rather have a stronger BLOCK than cheaper or more choices of bearings. The Crank can be cut alot without hurting its strength significantly. But removing material out of an already weak area of the block (compared to an aftermarket block) just isn't helping you at all. That thick part of the main doesn't remain that thick all the way up in OE blocks. Past that machined area it gets real thin. The "R" blocks and aftermarket B/RB blocks have that thickness all the way up for a reason; you need it for making serious safe power.
