January 09, 2009, 05:30:51 PM
| | |-+  400 block
Author Topic: 400 block  (Read 505 times)
2815spd
400 block
« on: October 01, 2007, 12:45:09 PM »
What's the best years for the 400 block? How much hp can one of these take?
2815spd
Re: 400 block
« Reply #1 on: October 01, 2007, 01:35:58 PM »
also  are the main sizes the same on a 400 and 440?
BBLM23
Poughkeepsie, NY
Re: 400 block
« Reply #2 on: October 01, 2007, 01:37:21 PM »
No.
Walter
1981 Dodge Aries 451 B1/BS
Best 1/4 9.871 at 136.01mph
1969 Dart Swinger 431 B1/BS
Best 1/4 10.649 at 126.45mph
Racing Pro in street trim.
1981 Plymouth Reliant 400
2815spd
Re: 400 block
« Reply #3 on: October 01, 2007, 01:49:37 PM »
I assume the beefier 440 main is better?
BBLM23
Poughkeepsie, NY
Re: 400 block
« Reply #4 on: October 01, 2007, 02:05:40 PM »
I don't think so, some people do. On a 440 the crank journal is larger but that means the main cap is thinner. I would rather have the 400 size crank journal with more meat in the main cap and block.
Walter
2815spd
Re: 400 block
« Reply #5 on: October 01, 2007, 02:13:22 PM »
On the after market blocks, are they all the 440 main?
BBLM23
Poughkeepsie, NY
Re: 400 block
« Reply #6 on: October 01, 2007, 02:15:12 PM »
I think so. The caps should be better on an aftermarket block, so less of an issue.
Walter
2815spd
Re: 400 block
« Reply #7 on: October 01, 2007, 02:18:48 PM »
I'm sending you a pm
speedymopars
Re: 400 block
« Reply #8 on: October 01, 2007, 02:25:52 PM »
KB uses the 440 size mains, and is able to use either early or late bearings (#3 thrust) .
2815spd
Re: 400 block
« Reply #9 on: October 01, 2007, 02:26:47 PM »
Where do find prices and specs for these blocks? Huh
Steve DeTar
Re: 400 block
« Reply #10 on: October 01, 2007, 05:20:48 PM »
The good ones are fairly hard to find.  All 383's and 440's have smaller main saddles....except the later 440 blocks cast late in 76 to 79 that end with 630 in the casting number
Engine by DeTar
daniel_depetro
Marquette, MI 49855 (Upper Peninsula)
daniel_depetro
Re: 400 block
« Reply #11 on: October 01, 2007, 05:57:26 PM »
The 1971-72 and industrial/cold weather castings are the thickest of all, however all 400 blocks have the good/thick webbing.
Read this: http://www.440source.com/blockinfo.htm
And this one: http://www.arengineering.com/articles/articleframe.html
1974 Dart Sport, 1974 Duster, 1971 Barracuda, 1974 'Cuda, 1970 Challenger R/T-SE, 1970 Challenger 340, 1971 Challenger 340, 1968 Coronet, 1970 Duster 340, (x2) 1973 Duster 340, 1971 Demon, 1972 Demon, 1973 Dart Sport 340, 1973 Dart Sport, 1977 Volare, 1971 Dart, 1970 Dart
rharveysr
Re: 400 block
« Reply #12 on: October 01, 2007, 06:40:17 PM »
 agree agree agree
What Steve said...Now the trick is..to find one of this animals....
oldkimmer
Re: 400 block
« Reply #13 on: October 02, 2007, 02:36:15 AM »
The run of the mill 400 block 451 stroker in my buddies old 70 duster ran 10.20s at 3000lbs.............kim.........
R5-P7 project
Re: 400 block
« Reply #14 on: October 04, 2007, 10:59:15 PM »
Hi Friend, I prefer to bore out my 400 mains to 440 size to get better bearing selection. Actually, it's cost effective too; as you would
probably (I know I would) align bore the block anyway.  Anyway, thats the way I would do it.
dustymopar
moparuk.com
Re: 400 block
« Reply #15 on: October 06, 2007, 04:54:48 AM »
It is also said that you should sonic test 400 blocks to ensure cylinder wall thickness
I guess this applies to all block really Undecided
Dustymopar (UK) - 1971 383 Plymouth Duster
I tried everthing else, but speed is the only answer
Re: 400 block
« Reply #16 on: October 06, 2007, 02:41:05 PM »
Bearing choices be danged! I'd rather have a stronger BLOCK than cheaper or more choices of bearings. The Crank can be cut alot without hurting its strength significantly. But removing material out of an already weak area of the block (compared to an aftermarket block) just isn't helping you at all. That thick part of the main doesn't remain that thick all the way up in OE blocks. Past that machined area it gets real thin. The "R" blocks and aftermarket B/RB blocks have that thickness all the way up for a reason; you need it for making serious safe power.
