November 23, 2008, 06:29:36 AM
| | |-+  anybody run a/c
Author Topic: anybody run a/c  (Read 264 times)
stuffedscamp
anybody run a/c
« on: October 02, 2007, 08:24:50 PM »
 my 73 scamp is an a/c car and i was wondering if anyone else is running a/c or if it is even possible?
69 GTS Clonvertible
GEAR+SLAMMER
Re: anybody run a/c
« Reply #1 on: October 02, 2007, 10:28:07 PM »
I'm running a/c and it is possible to do. I used a perfect fit system from classic auto air
Cry MY OLD RIDE HOPE IT IS WELL TAKEN CARE OF Cry
MikeR
Re: anybody run a/c
« Reply #2 on: October 02, 2007, 10:40:00 PM »
I have the Hot Rod Air kit, works great!
moparsky
Re: anybody run a/c
« Reply #3 on: October 03, 2007, 02:42:39 PM »
    69GTS's, your A/C work is a beautiful job, thanks for the pics !
    A really neat thing about ClassicAUto Air's "Perfect Fit" system is that it uses your OEM heater controls to control the A/C. Since you car is an factory A/C car to start with, call them & see how their system could use your OEM A/C controls. I have heard CAA has great tech support.
     MikeR do you have any pics of your Hot Rod Air evap install & which model do you choose and were you able to keep your fresh air vent functional ?
    Most A/C mfgs have much smaller evap units than Mopar installed, helps on under dash space, those OEM evap units were huge.
     My 2 cents...
Dallas, TX
Re: anybody run a/c
« Reply #4 on: October 03, 2007, 06:31:10 PM »
The classic system I was told, only works with the slide controls, not with the pushbutton style. But there is a cheaper way, Bouchillon Performance sells nice brackets, hose kits, and Sanden compressors, that will work with your existing a/c controls and evaporator. As a matter of fact, they have an A-body specific kit available, I priced it out for mine. $366 for the a-body kit. $160 for the "hidden a/c" bracket. and $80 for a reman Sanden compressor. Less than $600 for everything but the evaporator, which I have.
http://www.bouchillonperformance.com/
MikeR
Re: anybody run a/c
« Reply #5 on: October 03, 2007, 09:29:36 PM »
Mine doesn't allow for outside air, but I think the new systems allow for it, mine is about 3 years old.
For my system I built a bracket that holds it up as close as possible to the cowl (the vent are on top).  Also the controls for the hot rod air system are vacuum actuated, so no worries with routing cables.
stuffedscamp
Re: anybody run a/c
« Reply #6 on: October 04, 2007, 08:53:35 AM »
great pics and info thanks- 69 gts is your blower motor relocated with the kit you are running?
MikeR
Re: anybody run a/c
« Reply #7 on: October 04, 2007, 10:47:35 AM »
It's amazing that when I took the pictures I didn't notice the wires hanging down... now that's all I see, gotta get that fixed!  ha ha
69 GTS Clonvertible
GEAR+SLAMMER
Re: anybody run a/c
« Reply #8 on: October 04, 2007, 03:22:15 PM »
Yes, it is inside the car now, to the right of the a/c-heater box under the dash.........see pic
it is where the pass-side fresh air inlet used to be.
moparsky
Re: anybody run a/c
« Reply #9 on: October 04, 2007, 05:54:15 PM »
69GTS, great looking interior, thanks for the pic !
           Love that pistol grip shifter !
