January 09, 2009, 05:42:15 PM
| | |-+  Has anyone welded a sump in their tank?
Author Topic: Has anyone welded a sump in their tank?  (Read 327 times)
loiq
« on: October 03, 2007, 08:13:04 PM »
What all did you have to do? Did you have to put tank sealer in it? Buying a new tank...
gt
Re: Has anyone welded a sump in their tank?
« Reply #1 on: October 03, 2007, 09:57:16 PM »
I welded a sump in my tank.
Did not use any sealer, but it couldn't hurt.
gt
4spdfury
« Reply #2 on: October 03, 2007, 10:22:39 PM »
WE SEND OUR TANKS TO A RADIATOR SHOP AND HAVE THEM PRESSURE CHECKED FOR LEAKS AND THEN THEY FLOW SOLDER ON ALL THE WELDS. JUST A LITTLE EXTRA INSURANCE
Long Island, NY
« Reply #3 on: October 03, 2007, 10:42:12 PM »
I did it once to an old tank. It was very difficult to weld. The solder is a great idea as is the sealer. Why not get an Aeromotive or some other tank with a sump in it already? Also, I mentioned in another thread, a sumped tank isn't the best idea on a street car. They hang pretty low and the fittings are susceptable to damage.
67Satty
« Reply #4 on: October 04, 2007, 12:28:33 AM »
Something I used to see people do is just skip the sump and weld a fitting into the bottom/lowest point of the tank.  Anyone try doing it this way?
In the garage:  '67 Plymouth Satellite - once my 318-powered daily driver, now my project car with lots of "patina"
On the stand:  "Old School" '71 440 build:  "6 Pack" pistons at zero deck, Engle .534, 238@.050" Hyd, stock 452s, Performer RPM, Holley 850 DP, Hooker headers, FBO ignition.
loiq
« Reply #5 on: October 04, 2007, 10:14:20 AM »
I want to keep the stock tank but i need a bigger fuel outlet. Embarrassed No fuel cell, she wants regular car-type stuff anf that means filling the gas through the gas cap.  ::)Putting afitting in the tank sounds like a decent idea. Is that something will pass inspection at the track?
It's actually not a mopar, it's my wife's 69 Mustang but you guys know more than anyone on the Mustang boards. thank you
Long Island, NY
« Reply #6 on: October 04, 2007, 10:50:11 AM »
Someone must make a 1/2" pickup that fits in the stock pickup location. I'd do that.
Capt Jack
« Reply #7 on: October 04, 2007, 11:29:43 AM »
its also not terribly hard to replace the original pickup tube with a half inch one.
loiq
« Reply #8 on: October 04, 2007, 12:37:43 PM »
The Ford is like a Mopar with the piece that fits into the big hole in the tank. The fuel pickup is brazed in there. Maybe I could get a new one brazed in? Or get some fittings?
Long Island, NY
« Reply #9 on: October 04, 2007, 12:54:16 PM »
You could absolutely make it yourself with a bulkhead fitting. Put a hardline on the inside with a flare on the end to connect to the fitting. I did that on my brother's car.
7173Duster
« Reply #10 on: October 04, 2007, 01:21:20 PM »
That is a great idea, I did the whole bending up a new one and brazing it in.  Did you use a tube to flair adapter with the bulkhead?
gt
« Reply #11 on: October 04, 2007, 01:56:46 PM »
I had read a post on here not too long ago that someone is making a 1/2" pickup sending unit for the stock tank, just can't remember who.
gt
Long Island, NY
« Reply #12 on: October 04, 2007, 02:10:22 PM »
Just use a JIC bulkhead fitting. 37 degrees on both ends. The only hard part is flaring the hardline to 37 degrees. I have a flaring tool.
loiq
« Reply #13 on: October 04, 2007, 03:16:37 PM »
i think I will try that instead of sumping it. What do you use to seal the fitting? Some teflon washers or something?
Long Island, NY
« Reply #14 on: October 04, 2007, 06:46:43 PM »
I think Earl's sells washers with O rings bonded to the inside diameter.
