January 09, 2009, 10:32:16 PM
| | |-+  How much will I gain if I run open headers????
Author Topic: How much will I gain if I run open headers????  (Read 455 times)
JOEYMAN
« on: October 04, 2007, 02:25:14 PM »
I'm headed to the track on slick night T&T this coming wednesday. I want to drop the exhaust and run open headers. The exhaust is not mandrel bent. I have flowmaster 40series 2 chamber. The car runs 12.40's with full exhaust. How much should I gain. It will be cooler out than what I have been running in (temps).
2DR-ETR is coming your way!
Oct 10, 2007
Ran 12.296 @ 108.28 mph 1/4mile  1.751 60ft.
BBLM23
Poughkeepsie, NY
Re: How much will I gain if I run open headers????
« Reply #1 on: October 04, 2007, 02:40:06 PM »
I took the 4 inch bullets off and gained nothing...
Walter
1981 Dodge Aries 451 B1/BS
Best 1/4 9.871 at 136.01mph
1969 Dart Swinger 431 B1/BS
Best 1/4 10.649 at 126.45mph
Racing Pro in street trim.
1981 Plymouth Reliant 400
http://bbdart.com/parts/parts.html
JOEYMAN
« Reply #2 on: October 04, 2007, 02:58:10 PM »
Well I have full exhaust with tail pipes all the way out to the bumper.
Oct 10, 2007
Capt Jack
« Reply #3 on: October 04, 2007, 03:06:49 PM »
Ive done the old "unbolt the collector and let them hang" thing before.  other than the teeth rattling increase in noise (and fumes) I noticed zero difference from a well built exhaust system.
JOEYMAN
« Reply #4 on: October 04, 2007, 03:13:13 PM »
I have reason to believe that I will gain because I don't have mandrel bent pipes. Just something put together from the exhaust shop down the street.
The bends look flat as it goes up and over the rearend
I should at least gain some MPH
Oct 10, 2007
illfish
« Reply #5 on: October 04, 2007, 03:29:05 PM »
Lose some weight or find it in the motor.
JOEYMAN
« Reply #6 on: October 04, 2007, 03:53:38 PM »
I've always heard that you can gain 2 tenth without mufflers. That is a restriction.
There is only one way to find out and that is take 6 bolts off and  drag tree 4 speed
Oct 10, 2007
abodyjoe
South Jersey...
abodyjoe
« Reply #7 on: October 04, 2007, 04:09:41 PM »
think it depends alot on your exhaust.
have a friend that gains a solid 2 tenths in his cuda when he opens the cut outs...    he is running straight 3" pipes to flowmasters and dumps in front of the rear..
my car runs exactly the same open or close.. i'm running 3" pipes to a X-Pipe and 3" dynomax super turbo mufflers... was running tail pipes but now that they are off ther has been no difference.
jamesdart
« Reply #8 on: October 04, 2007, 09:29:11 PM »
when i had the 3" on my dart with flow techs, i picked up nothing but ringing ears when  i opened the exhuast. those arent even a strait through muffler. you might gains some, but you should also try jetting up a tad when you open it. what size is the motor and what size pipes? i say just build the right size exhuast with some strait through mufflers.
496dart
« Reply #9 on: October 05, 2007, 03:46:11 PM »
I PICKED UP .5  in e.t.  when i installed a 3" system on my car.
Leave it on.
Joe-Dokes
« Reply #10 on: October 05, 2007, 05:50:27 PM »
As someone with a real hearing loss, please protect your hearing.  Though my wife doesn't bother me as much, since its gotten worse.  hammer
A modern well designed exhaust system has a negligible effect on hp.  I'd leave the system on.
Make sure you have mandrel bent with an x pipe and good mufflers.  Rather than pull your system off, simply upgrade the portions that need it.
By the way 496 Dart what were you running before the 3" mandrel bend setup 1" with a cork?  Half a second is a serious gain.  Good Job.
Regards
Joe Dokes
Eats4dz64
Some day I will be a real racer!
« Reply #11 on: October 05, 2007, 08:24:38 PM »
The reason most people do not gain power from removing there exhaust is that there exhaust allready flows very well, or the carb is well tuned to the motor in its current state. Try going up 2 jet sizes in the secondary then see if you gain some ET from it.
The exhaust on my dart is very porly done, so when I drop the exhaust it runs much better and allows me to jet up at the same time.
Just food for thought.
MyCreation68
« Reply #12 on: October 05, 2007, 09:23:12 PM »
from the way you sound your convinced already you will make gains from it. So as you said theres only one way to find out and thats taking the exhaust off and trying.
-98 Dodge Ram SS/T 5.9L auto all stock
-92 Dodge Power Ram W250 5.9L CTD 5spd 4x4
-46 Fargo
Womanator
Womanator Racing
« Reply #13 on: October 05, 2007, 10:44:03 PM »
I lose a tenth when I put my bullets on my 68 dart it's a 9.5 sec car.Maybe if I jetted down when I put the muff's on it would stay the same.I tune for open headers.
496dart
« Reply #14 on: October 06, 2007, 03:35:47 AM »
Regards
Joe Dokes
no b.s. brother.
its all in the engine and torque curve/combo --thats why you see guys bolting on 12"-16" header extensions.  I will have to dig out my logbook , but,  i ran  one weekend and then on wednesday the next, had my 3" exhaust put on (with $19 3" Summit glasspacks)  , and--no other changes.  same weather-- "almost"  a 10th  in ET.  My combo loved the back pressure.  Believe me-----I was suprised!
dustymopar
moparuk.com
« Reply #15 on: October 06, 2007, 04:48:58 AM »
I gained nothing, but run a 3"  1/2 system with Flowmaster 40's
BUT, it does sound good and is a goos chance to make a lot of noise Grin
Dustymopar (UK) - 1971 383 Plymouth Duster
I tried everthing else, but speed is the only answer
« Reply #16 on: October 06, 2007, 02:50:52 PM »
Depending on your exh' system, maybe as much as two tenths to as little as nothing at all.
My 400 stroker, open header, went (1/8th mile) 6.80 @ 100.1 MPH without and 6.88 @ 101.19 MPH with 3 1/2 exh' w/ flowmasters. The exh also added about 50lbs (using the right arm curl scale method of weighing) to the overall weight of the car too.
