Topic: Early A-Body B/RB fenderwell Headers? (Read 520 times)
Eats4dz64
Some day I will be a real racer!
Im sure this question has been ran over a half million times but unfortunatly I havent found an answer.
Anyone know of any production headers or how much Modification it takes to use the 67 and later fenderwell headers?
no one makes them.. custom make them is the best bet.
CudaDon65
If you use Bill's AlterK front end you can use 1967 and up smallblock headers (not Fenderwell) and keep everything under the car. Are you using a smallblock? Do you want to run fenderwell header? Take a look at RMS in the gallery, there's pics of an early-a with a smallblock with headers and a bigblock (440). Hope this helps.
fstfish66
this is just a suggestion,,,i havent seen a pair of these headers off of an engine,,but the street rodders use block huger style headers,,a company named sanderson makes all kinds of block hugger style headers for all type of engines,, they do make a set for a big block mopar,,but im not sure where the exhaust exit is located,,,if it would interfear with the steering box,,, 67 and up big block fender wells headers will dump out at the edge of the fender,, you would be able to see the colector under the rocker panel,,ive seen it done before,,,
1966 barracuda blown 340 4 speed tubbed 33x22 1940 dodge street rod hemi with A/C 2002 cummins ram dailey driver
jyrki
No chance of the blockhuggers fitting. Otherwise, you could use SB's with those blockhuggers too. Custom made, or modified '67 & up fenderwells are about your only chance. Don't know which is easier because I haven't modified the newer headers myself, but I know which solution is better.
