January 09, 2009, 10:33:58 PM
| | |-+  Pertronics ignition - initial settings? - 273 V-8
Author Topic: Pertronics ignition - initial settings? - 273 V-8  (Read 190 times)
« on: October 06, 2007, 12:33:26 AM »
So I just mine and I'm just wondering about a good street setting. We have a choice of distributor options, mechanical spring advances and advance limiters (12-16-20 degrees). it also has a vacuum advance. Now the box has a setting for COA (crank offset angle) This is a setting for the second shot to the plugs. I'm hearing 2-4 degrees. Does anyone have this set-up? What do you think I should start with? Oh, I have the idle advance at 10 degrees with the vacuum hose removed and plugged.
Jim
illfish
Re: Pertronics ignition - initial settings? - 273 V-8
« Reply #1 on: October 06, 2007, 01:17:04 AM »
Run 12 degrees advanced and 36 total.
« Reply #2 on: October 06, 2007, 03:04:08 PM »
