December 01, 2008, 11:23:42 PM
| | |-+  battery disconnect
Author Topic: battery disconnect  (Read 950 times)
Chris_Holliday
72 dart 440, 906's, .509 runs 12.30's
battery disconnect
« on: December 28, 2005, 07:34:00 AM »
I am relocating the battery to the trunk and wondered about what type of shut off switch? I am using an alternator and would like to know if anything has to be done special.  Let me hear the ideas
Ohio
Brad4406
Re: battery disconnect
« Reply #1 on: December 28, 2005, 08:32:46 AM »
I went with the Summit switch just because it was a lot cheaper than the brand name ones.  A switch is a switch, why pay more.
Brad
Brad4406
brawn4406@yahoo.com
Bigcube
« Reply #2 on: December 28, 2005, 03:51:55 PM »
Brad
Not really, the cheapo switches are reated for 20 amps, the starter draws much more than that.  A cheap swtch is usually the culprit for some voltage drop between the battery and the starter.  Do yourself a favor and get a good Flaming River switch, they are rated at 200 amps.
Jim
Best 1/8 1.259 60', 5.67@121
Best 1/4 8.94@151 All Motor
http://www.bigcube.org/
Brad4406
« Reply #3 on: December 28, 2005, 05:10:18 PM »
Good point, I haven't had problems with mine but I can see your point.
Brad4406
brawn4406@yahoo.com
GTS225
« Reply #4 on: December 28, 2005, 11:02:08 PM »
I got the Taylor piece from Summit.  I think it was only a couple bucks more than the Summit one, but it also has the extra contacts for the alternator lead.  They claim it's rated at 200 amps.
Roger
Chris_Holliday
« Reply #5 on: December 29, 2005, 08:48:50 AM »
Do I have to do anything to the alternator wiring or just the main battery cables?  I will get a 200 amp switch.
Ohio
Bigcube
« Reply #6 on: December 29, 2005, 10:19:11 AM »
To be wired correctly for the track, the kill switch must kill the motor. Hence the name  Roll Eyes If you have an alternator on the car and the factory wiring, the car will contiue to run on the alternator when you throw the switch.  The simplest solution is to convert to a single wire alternator and wire it direct to the battery.  duster
Jim
sr71mopar
Santa Rosa, CA.
« Reply #7 on: December 29, 2005, 10:22:21 PM »
Thats a good point.
400dartguy
« Reply #8 on: December 30, 2005, 02:15:57 AM »
Hey not to swipe the post- but where did you street driven guys mount the switch- Im about to do the battery when I do minitubs and spring relocation.  I thought through the bumper, but what happens when you have a parking lot oops?  Maybe extra wire and put it on the decklid??   thank you thank you bbd sign
Chris_Holliday
« Reply #9 on: December 30, 2005, 04:13:20 AM »
Thanks for all the good tips.  I definately need it to kill the motor and be track legal.  Wink
Ohio
Bigcube
« Reply #10 on: December 30, 2005, 08:23:56 AM »
Here's mine.  It's mounted inside the trunk with a push/pull lever.
The knob sneaks through between the bumper and the tail light.
I still have to lable it with the "push off" lettering but have avoided it for about 7 years  LOL
Jim
400dartguy
« Reply #11 on: December 30, 2005, 09:38:43 PM »
Bigcube, thanks for the pics- thats a really cool idea- you have heard that imitation is the sincerest form... Grin thank you
blackbetty
« Reply #12 on: December 31, 2005, 01:04:47 PM »
I am using the same Flaming river switch as Bigcube but it is mounted on the framerail and the rod sticks out under the valance panel. I had to make a guard for it so it didn't get covered in rubber or hit with something coming off the tire. Sorry I dont have any pics of it.
dartman_of_tampaba
« Reply #13 on: January 06, 2006, 12:55:23 AM »
I mounted my flaming river switch next to the battery in the trunk on the pass side,the Mopar Muscle Valient article had some good pics of it probably 9 months ago.
You should check out Mark Hamilton's info at www.madelectrical.com, very good stuff and provides the info to do the job correctly with the necessary safety features.
Greg
Chris_Holliday
« Reply #14 on: January 08, 2006, 04:42:14 PM »
Thanks I will check the article.  I want to be sure the alternator is not a problem when I turn the switch off.
Ohio
green67cuda
« Reply #15 on: January 13, 2006, 02:27:40 PM »
I mounted mine to the center brace where the trunk latches, put a lever on it to make it a push-pull type, and brought it out right under the bumper, between it and the license plate.
Dartsport
« Reply #16 on: January 13, 2006, 02:47:11 PM »
Dartsports are different in the back, lots of room for switch.
