July 09, 2008, 12:33:10 AM
| | |-+  T-56 6-speed discussion...
Pages: 1 2 3 [4] Go Down Print
Author Topic: T-56 6-speed discussion...  (Read 5782 times)
Think3205
A work of art in progress...
Re: T-56 6-speed discussion...
« Reply #90 on: April 07, 2008, 09:07:38 PM »
Do you know which version for a 6.1 or 3G hemi?
Also does anyone know if the SRT-10 Ram truck Viper transmission is the same as the true Viper car transmission. I imagine the input shaft is the same since it's the same motor, but how about the gear ratios/spread?
that's a good question, not sure... i've seen lots of info on the t56 from vipers but not from the srt-10 rams... maybe the dodge dealer could tell you...
zpsull01
« Reply #91 on: April 07, 2008, 09:11:55 PM »
A friend of mine gave it to me it came out of a 93 camaro so I needed to change the input shaft to the longer LSx shaft.
Does anyone know if the viper t-56 has the longer input shaft? Or what exactly is this affecting?
And I looked back through MikeR's post and he was using a modified scatter shield because the quicktime bellhousing was not available at the time. But besides that he was using a firebird clutch, a big block flywheel, and a Viper throwout bearing all on a viper spec t-56. Does anyone know if those same parts would work with the quicktime bellhousing?
And I have no idea as for what to do for a slave cylinder so if anyone has any insight on that it would be great.
blackbetty
« Reply #92 on: April 08, 2008, 09:27:12 AM »
I am using a big block flywheel camaro clutch disk and mopar presure plate. The slave cylinder should be part of the throwout bearing.
Make the asphalt bleed!
zpsull01
« Reply #93 on: April 08, 2008, 04:14:08 PM »
Thanks for the info, and could you provide alittle more as for more specific part numbers? Also besides these parts what else is needed. I know nothing about this conversion but had the opportunity to pick a t-56 up so i couldn't turn it down.
blackbetty
« Reply #94 on: April 09, 2008, 10:07:33 AM »
I dont have the exact part numbers. I got everything from napa I went in there and figured it out. I think I am using a 10.5 inch clutch from a early 90s camaro 91 or 92. The presure plate and flywheel are 10.5 inch dodge parts and the throwout bearing is for an LS1 camaro.
zpsull01
« Reply #95 on: April 09, 2008, 11:08:35 AM »
Thanks, that is more of what I was wondering. I didn't know if I had to use all t-56 parts or if want you said there would work. Also do you have your setup in the car and running yet?
blackbetty
« Reply #96 on: April 09, 2008, 01:45:04 PM »
I dont have it running yet but it is bolted together and sitting in the chassis. It wont be running for a couple of months the chassis needs finished.
MoparCar
« Reply #97 on: April 09, 2008, 07:22:40 PM »
I finally got a chance to call Quicktime bellhousing and talked with Ross there. They are a very helpful company. I will definitely buy from them. Don't quote all the details on this---call to confirm. I was writing fast.....I may have missed a bit.
They make several bells for different T-56 and engines.
Their T-56 GM version does use the LS1 style transmission. This can use a hydraulic throw out bearing.
Their T-56 Viper version uses of course the Viper T-56 and is set up for the stock Viper fork and mechanical slave actuator. (can anyone verify that the viper uses a fork and slave?) I don't know Vipers.
The new TR6060 high performance unit from OEM applications utilize a integrated bellhousing if I understood correctly, but Tremec has one out or is coming out with the same 6060 transmission with a "divorced" bell to use the standard T-56 bolt pattern which will bolt to their bells. Tremec is calling this the T-56 Magnum. I see Tremec mentions it on their website if you search. No details though. Quicktime said this will bolt up to one of their bells.
My question about the 6.1 hemi and the T-56 is answered by the same above, just that the LA engine bell is used with a LA starter and remains on the driver's side at the 7 o'clock position. They are coming out with a dedicated new gen hemi 5.7/6.1 bell in a couple of months that will allow the starter on the passenger's side also at the 5 o'clock position.
Quicktime does not sell or provide pilot bearings. You need to go to NAPA or somewhere and figure it out or have one machined.
They basically said they can mate up almost any T-56 to any Mopar engine. It might require a different  input or front plate at most.
This is becoming a great thread!
Wes
sycboi
« Reply #98 on: April 11, 2008, 09:50:08 PM »
I believe Vipers used both types of T/O bearing, hydraulic and mechanical, over the years.  Although I am not sure what years used which style.
I'm setting my T-56 up with a hydraulic T/O as we type...
-Michael
MoparCar
« Reply #99 on: April 16, 2008, 07:43:13 AM »
sycboi,
Thanks for the Viper info. I too plan on going with the hydraulic TO also. Easier and cleaner for my application. What brand of set up did you use?
Next question:
Anyone have any additional info on the new T-56 Magnum (the TR6060with the standard T-56 bold pattern)? Release about June, but that's all I know.
Wes
sycboi
« Reply #100 on: April 21, 2008, 09:54:51 AM »
I originally had a McLeod but the working range will not fly unless I rebuild it with a new/different sized piston...
So, I think I am going to go with a Ram or some other type at this point since I need to change piston size anyways...I might as well switch to a new/better line set-up like the Ram T-56 units have...
-Michael
MyCreation68
« Reply #101 on: May 20, 2008, 05:38:23 AM »
maybe this question has been answered before but I just havn't seen it. I'm wondering where the shifter would come out with the array of T56 transmissions that came in all these different vehicles. If possible I want to reuse my stock console after install so nobody is the wiser of what I've got under the shifter.
I also have a question on bellhousing. I am building a car that will eventually see a turbo charged slant, I figured because I'd likely get a custom built SFI approved bellhousing that I might as well get it built for a better trans anyways. so I just wanted to make sure with the guys who have already bought one that the bellhousing I see on the trans already is removable?
I don't suffer from road rage, I enjoy every minute of it.
My vehicles:
-1984 Dodge Ramcharger 318 auto 4x4 atc stock beast
-1968 Dodge Dart GT 6cyl auto buckets console work in progress
-1966 Bridgestone 90 Deluxe
-1946 Fargo 3/4 ton
Bill_Reilly
Administrator
White Haven, PA
« Reply #102 on: May 22, 2008, 06:36:36 PM »
So where does one buy the bigblock-T56 pilot bearing? Anyone find it available anywhere?
MoparCar
« Reply #103 on: May 23, 2008, 03:49:49 PM »
I don't have an answer for that either.......
I have the same question regarding sourcing a pilot bearing for a t-56/6.1L Hemi combo. Anyone? Quicktime said I may have to have one machined?
rjsjea
ProTouring Demon
« Reply #104 on: May 23, 2008, 04:06:07 PM »
Keisler would know probably.......they make a 6.1 conversion
[img]
Bill_Reilly
Administrator
White Haven, PA
« Reply #105 on: May 23, 2008, 10:30:51 PM »
Got in touch with my old buddy Geoff - he's fixing me up.
Not much info, but the text is in fact accurate Grin
http://gerkoenterprises.com/
rjsjea
ProTouring Demon
« Reply #106 on: May 23, 2008, 10:40:10 PM »
I thought Gerko was De-funk??
[img]
Bill_Reilly
Administrator
White Haven, PA
« Reply #107 on: May 23, 2008, 10:52:29 PM »
I'm told Geoff and his brother parted ways unfortunately, but Geoff continues to work on things. I havent spoken to his brother, so I'm sure what he's doing.
I just always dealt with Geoff, so I call him by default.
blackbetty
« Reply #108 on: May 30, 2008, 04:28:08 PM »
The trans will not fit in the stock tunnel and the shifters come out in the middle in the tail of the trans. You can probably modify the shifter to move it over but the tunnel will need modified.
MyCreation68
« Reply #109 on: May 30, 2008, 04:51:30 PM »
I know the tunnel will require modification. but I'd like to use my stock floor shift console so the car looks "stock"
My vehicles:
-1946 Fargo 3/4 ton
Pages: 1 2 3 [4] Go Up Print
