Topic: will 235/60-15 fit a '65 barracud ?? (Read 844 times)
joesnow
will 235/60-15 tires in 15x7 rims fit on all four coners of a 1965 barracuda? I don't know the offset. Probably a stardard depth. Thanks.
djwhog
no on fronts, yes on rear even at standard height, need at least about 4" offset in rear, will be close on front of rear 1/4s!
joesnow
What size will fit up front? 15" x 6" wheel. Thanks.
Keith Mopar
I ran 16 X 6 with 225 50 16's on the front of my 65 Cuda and no problem. they didn't even come close to rubbinmg, These rims had a 4.25 back space, and the spot that was close to rubbing was the when the wheel was at lock the tire was 3/8 on an ionch from the sway bar.
Keith Mopar 74 440 Duster, 65 360 Cuda, 89 super 60 Shadow, 99 Ram, 96 Avenger, 91 Daytona, 91 Lebaron Convertible
russ446
i was wondering about running a 225/60/16 on the rear of the car?
djwhog
Will fit also, just need the larger 4" or so offset rims.
Keith Mopar
I ran a 235 55 16 on the rear my 65 Cuda no problem. The rims had approx 4.7 back space and 6 inch wide. My rear end is also moved back about 1/2 an inch.
topchopvalle
I run 255/50-14 on my -65 Valiant, no problemo!
grimreaper
I have a disc brake / upper A-arm setup from a 74 Duster that I want to put on my '64 Valiant. I'm told this makes the front track wider. Does anybody know how much wider it is? The reason I want to know that is to lead into my real question. Will 205-55R16 tires on 16" x 7" wheels with a 4" backspace fit the '64 Valiant after the disc upgrade?. It's currently rolling on 215/70R14s on 14 x 6 SBP wheels with 3-5/8' backspace and the 9" drum setup. They fit OK, but if the disc conversion sets the wheels out I'm not sure...... Does anyone know, or what wheels/tires do you run on early A's with the 73-76 disc brakes?
Thanks!
pishta
Who sells those tires and how much?
