January 09, 2009, 11:57:28 PM
| |-+  Early A-bodies
| | |-+  will 235/60-15 fit a '65 barracud ??
Author Topic: will 235/60-15 fit a '65 barracud ??  (Read 988 times)
joesnow
s.e.pa.
« on: October 12, 2007, 05:14:26 PM »
will 235/60-15 tires in 15x7 rims fit on all four coners of a 1965 barracuda?  I don't know the offset. Probably a stardard  depth. Thanks.
djwhog
Re: will 235/60-15 fit a '65 barracud ??
« Reply #1 on: October 12, 2007, 10:01:04 PM »
no on fronts, yes on rear even at standard height, need at least about 4" offset in rear, will be close on front of rear 1/4s!
joesnow
s.e.pa.
« Reply #2 on: October 12, 2007, 10:18:40 PM »
What size will fit up front? 15" x 6" wheel.  Thanks.
Keith Mopar
turnertk@msn.com
« Reply #3 on: October 13, 2007, 03:00:34 AM »
I ran 16 X 6 with 225 50 16's on the front of my 65 Cuda and no problem. they didn't even come close to rubbinmg, These rims had a 4.25 back space, and the spot that was close to rubbing was the when the wheel was at lock the tire was 3/8 on an ionch from the sway bar.
Keith Mopar
74 440 Duster, 65 360 Cuda, 89 super 60 Shadow, 99 Ram, 96 Avenger, 91 Daytona, 91 Lebaron Convertible
russ446
« Reply #4 on: October 16, 2007, 07:43:25 AM »
i was wondering about running a 225/60/16 on the rear of the car?
djwhog
« Reply #5 on: October 16, 2007, 09:51:25 PM »
Will fit also, just need the larger 4" or so offset rims.
Keith Mopar
turnertk@msn.com
« Reply #6 on: October 17, 2007, 05:24:56 PM »
I ran a 235 55 16 on the rear my 65 Cuda no problem. The rims had approx 4.7 back space and 6 inch wide. My rear end is also moved back about 1/2 an inch.
bbd sign
Keith Mopar
topchopvalle
« Reply #7 on: October 18, 2007, 10:41:33 AM »
I run 255/50-14 on my -65 Valiant, no problemo!
grimreaper
« Reply #8 on: January 14, 2008, 11:02:51 PM »
 I have a disc brake / upper A-arm setup from a 74 Duster that I want to put on my '64 Valiant.  I'm told this makes the front track wider.  Does anybody know how much wider it is?
The reason I want to know that is to lead into my real question.  Will 205-55R16 tires on 16" x 7" wheels with a 4" backspace fit the '64 Valiant after the disc upgrade?.  It's currently rolling on 215/70R14s on 14 x 6 SBP wheels with 3-5/8' backspace and the 9" drum setup.  They fit OK, but if the disc conversion sets the wheels out I'm not sure......
Does anyone know, or what wheels/tires do you run on early A's with the 73-76 disc brakes?
Thanks!
pishta
« Reply #9 on: March 17, 2008, 11:42:47 PM »
Who sells those tires and how much?
