October 12, 2008, 05:34:15 AM
| | |-+  Drive shaft length
Author Topic: Drive shaft length  (Read 373 times)
5258
bigblockdart.com
Drive shaft length
« on: October 15, 2007, 11:40:50 AM »
Fixing to change out the punny 7 1/4 rear and drop in a 8 3/4, running a four speed, Does anyone know what the drive shaft length will be needed for the swap. I know my current length will not work but I have cut and welded one before so the work would not be an issue, trying to get idea for what the length diference is.
Thanks
5258
5258 Performance  Shelbyville, Tennessee "Where the MOPAR factory built and race ready hotrods live again"
Re: Drive shaft length
« Reply #1 on: October 15, 2007, 12:11:05 PM »
Since every car is different I like to measure for mine. Put the yoke all the way in the transmission and with the suspension loaded measure center to center on the yokes. Subtract 3/4" and you'll be good.
sunsetdart
us4ever365@hotmail.com
« Reply #2 on: October 15, 2007, 02:00:39 PM »
When you do the measuring, make sure ALL the weight is on all 4 tires, if you don't the shaft will not fit.
lake worth, florida
55robert@bellsouth.net
« Reply #3 on: October 15, 2007, 02:31:58 PM »
  it'll be the measurement from the center of the rear end yoke to the seal rim on the trans less 3 1/2".
doug 371
« Reply #4 on: October 16, 2007, 09:34:58 PM »
factory service manuals show the stock lengths...if u need length for a dart i can help but no manual for a duster
bigblockdart.com
« Reply #5 on: October 17, 2007, 02:34:39 PM »
Yes need for a 4 speed / 8 3/4 69 dart combo.
Thanks
brg1966
It's still the "stupid black car"
« Reply #6 on: October 17, 2007, 06:58:35 PM »
For a 4 speed and 8-3/4 the length is 48.6"
An 340 and Big Block, 727 and 8-3/4 length is 44.88
This is from a 1968 plymouth service manual
"The Stupid Black Car"
Small Block
« Reply #7 on: October 17, 2007, 08:59:58 PM »
Like Jim said: Don't forget the 3/4". I put it all together and haul it to the driveline shop and let em measure it thenselves and then they fabricate it.
doug 371
« Reply #8 on: October 17, 2007, 11:21:18 PM »
he needs the info for a dart not a plymouth...my dodge manual says 51.53"
