July 24, 2008, 02:17:18 AM
| | |-+  Which rear disc brakes and what ends?
Author Topic: Which rear disc brakes and what ends?  (Read 485 times)
zpsull01
« on: October 16, 2007, 05:04:45 PM »
I am looking for some rear disc brakes to use on my 72 duster and I know that I can get the explorer kits and stuff for like $500 but is there any setups that I can use from a newer car from a u-pull yard? I am soon going to have my Dana 60 narrowed so I can go with whatever ends that I wish. Is it just a matter of pulling all the components from the donor car and putting them on my rear if I have it set up with the same ends?
rjsjea
ProTouring Demon
Re: Which rear disc brakes and what ends?
« Reply #1 on: October 16, 2007, 08:40:57 PM »
brand new wilwood setup is about $550, beats a junk yard set for $500.  IMHO
[img]
zpsull01
« Reply #2 on: October 16, 2007, 11:40:34 PM »
Do you really think that it would be close to $500 for a scrap yard set? I figure that I'll get new rotors and rebuild calipers anyways. Thats what I'm doing on the front for now, but I do plan on getting the wilwood kit after I get the car together and get everything worked out.
rjsjea
ProTouring Demon
« Reply #3 on: October 17, 2007, 02:18:07 AM »
No, I dont know what a junk yard set-up will cost. I thought the explorer kit you mentioned was from a yard for $500.    Dunno
[img]
loiq
« Reply #4 on: October 17, 2007, 10:42:18 AM »
You can go with scarebird adapters.
www.scarebird.com
Ace
« Reply #5 on: October 18, 2007, 12:38:51 PM »
Haha there are a lot of threads about this.
I used 9" ends and did Malibu Front Calipers and Jeep somthing rotors.  I'll get you part numbers today.  Best part is, I got everything for under $100.00
Ballz Deep Racing
Where Enough is NEVER Enough
www.midamericamusclecar.com
zpsull01
« Reply #6 on: October 18, 2007, 03:58:08 PM »
Thats a great looking setup for the price. Please do get me part numbers. What caliper bracket did you use to mount those with? Also what axles are you running?
Ace
« Reply #7 on: October 18, 2007, 05:05:05 PM »
I had 'em put the brackets on when they narrowed it for me at www.quickperformance.com.  If you call up there ask for Doug.  I think the brackets were $15.00 each or a pair I don't remember.  I think I'm in the whole rear end for under $1200.00 since I had the case layin' around.  I'll get the part #'s when I get back out to the shop for ya.
The axles are the Quick Performance 35 spline's with a spool.
Ballz Deep Racing
zpsull01
« Reply #8 on: October 18, 2007, 05:41:22 PM »
So are you using their kit or did you supply your own calipers and rotors?
Ace
« Reply #9 on: October 18, 2007, 08:09:26 PM »
It's not really a "KIT" per say, it's just the parts he uses.
I know the calipers are like '81 Malibu fronts.
Caliper Part #'s R125FK and R126FK
Rotor Part #'s 5108
I THINK these are Carquest part #'s.
Ballz Deep Racing
