August 29, 2008, 02:13:02 PM
| | |-+  Spring of 08 Body work Project... Going to need help with this one! PICS!
Author Topic: Spring of 08 Body work Project... Going to need help with this one! PICS!  (Read 349 times)
wjaholic
« on: October 22, 2007, 09:55:47 PM »
Alright, long story short from what I can tell the guy that had this car before me found a ditch that didn't like him. The rocker panel is a damaged as well as the quarter. The door has long since been changed. I am going to get a new quarter panel and use as much of the old one as possible. I just happen to be able to track down a "B-Post" and an entire rocker panel from another car.
My question is, What would be the best way to tackle something like this?   Dunno
The car has changed alot since these pictures were taken, other than the sheet metal pretty much everything has changed on it.
“Give me a place to stand and a lever long enough and I will move the world.” - Archimedes
eldubb440
eldubb440
Re: Spring of 08 Body work Project... Going to need help with this one! PICS!
« Reply #1 on: October 22, 2007, 11:30:38 PM »
get the rocker and door jamb tacked into place first...... line the door up EXACTLY where you want it, make sure you have a nice straight gap between the door and rocker.......then simply replace the quarter, trunk extension ect..... DO NOT weld anything solid untill it all fits.....it will fall together nicely
heres a little inspiration
rjsjea
ProTouring Demon
« Reply #2 on: October 22, 2007, 11:37:15 PM »
 agree.....get the jamb tacked in the correct place, then quarter panel.
[img]
wjaholic
« Reply #3 on: October 23, 2007, 12:00:41 AM »
Very Cool! Very Very Cool! Thanks for the inpiration!!   duster
illfish
« Reply #4 on: October 23, 2007, 01:01:36 AM »
Is it rare?
wjaholic
« Reply #5 on: October 23, 2007, 08:15:16 AM »
Is it rare?
Is the car rare? If you were to look to look on E-bay you would see a bunch of them. But, there wouldn't be a single one with in 200 miles of here.  Is it rare like a convertible Hemi Road Runner, No. Is it rare around here, Yes. In one instance I had to call a junkyard 300 miles away to get parts for it.
Dallas, TX
« Reply #6 on: October 23, 2007, 10:18:44 AM »
First tip from me, speaking from experience, change the name from "spring 08 project" to "hope get it finished by the end of 2008 project".
loiq
« Reply #7 on: October 23, 2007, 01:39:21 PM »
That B post, the part with the door striker, is all spot welded in. Drill all those out and replace it first the go for the rocker. I can't see where the rocker is bad other than rust in the dogleg?
signet
« Reply #8 on: October 23, 2007, 09:12:56 PM »
have you taken all the interior on the left side out yet, glass fuel tank ect?
then i would clean up were the spot welds are on the car and donor chunk.
then fill the fridge and think about it for a few days.
wjaholic
« Reply #9 on: October 23, 2007, 11:40:07 PM »
The interior is out of the car. The seat was worn so much so I couldn't sit on it with out a piece of plywood to cover springs. I found a milk crate be much better. I dropped the gas tank, and have rebuilt the front end and swapped the rear end out. Before I put the new gas tank in I wanted to finish the trunk, so I am dealing with the wheel wells and trunk extensions right now. My goal is to get the trunk sealed up before winter. This way I dont put the new fuel system in (new gas tank, sending unit, and fuel line) and screw my self over by having to take it back out to finish the trunk. I am going to rebuild the transmission this winter. Start putting it all together in early spring (440 is finished). Once I get it to the point to where I can limp it around the drive way I will weld in sub frame connectors and tackel the b-post, rocker and quarters. The rocker was pushed in slightly, I don't know that I can pull it back out. So I picked up the replacement while I was getting the b-post. Two birds with one stone. If I am satisfied with how the original rocker turns out I will sell the replacement  Dunno .
loiq
« Reply #10 on: October 24, 2007, 09:43:00 AM »
Roll it out next to a tree, weld some sort of hook to the rocker and hook a come-along to it and see if you can pull it out. You can't wreck it any worse than it is and you have a replacement so you have nothing to lose. The less you have to cut out and repair the better.
