Topic: help please (Read 237 times)
440dstr
finally got 360/4spd in my old dart original 318/904 . swapped steering colum and pedals from stick duster i had a long time ago . engine wont turn over with the ignition switch but will if i jump the relay but no spark i assume because no nuteral saftey switch in car yet  ? so i guess my main  ?? is what wiring needs to be changed for my swap to function as factory . 73 dart also car has been stored with no engine for about 10 years what color is+ and - on the coil. p.s. new d-c valve covers look really sharp!! thanks
4 speeds have no neutral safty switch. some had a switch on the clutch pedal but I'm not sure whe nthey started it... you can either jump the extra lead on the starter relay to gound (the one that runs to the tranny not the one that runs to the ign switch). or buy a 4 speed starter relay. The 1st solution is the cheapest  .
4 speeds have no neutral safty switch. some had a switch on the clutch pedal but I'm not sure whe nthey started it... you can either jump the extra lead on the starter relay to gound (the one that runs to the tranny not the one that runs to the ign switch). or buy a 4 speed starter relay. The 1st solution is the cheapest  . remember it will also start while in any gear or out of gear. BE CAREFUL PLEASE it only takes ONE TIME to change your life.
440dstr
so how is the 4 spd relay different than the auto?An on the back of the trans is just for reverse lights?
The factory four speed starter relay has the "G" terminal grounded to the case, until they started using the clutch pedal switch. This was stopped after some time, too. Ground the terminal and ALWAYS start with the trans in nuetral and your left foot on the brake. This will save your thrust bearing.
the 73 i just pulled has the clutch pedal swith w green wire running to the relay
