My combo is a 451 in an A-body, SS springs, ladder bars, 4.56 gears, 10" 3800 stall converter, 11.5" x 29.5" M/T slicks. There are 3 holes for adjustment at the front of the ladder bars - presently using the center hole - pinion angle is at 4*. 6 cyl torsion bars and 90/10 shocks up front. I foot brake and usually leave off idle at 1200 rpm.
!st Question: if I were to raise the ladders to the top hole, would I have to re-adjust the pinion angle? 2nd Question: what are the odds of getting some "air" under the front tires?
505 - 400 block EZ-1's, 4.56 gear, 8" PTC 4500 stall best of 1.402 60', 10.338 @ 128.73
yes you'll have to at least check the pinion angle, it may be within the 2 to 3 * range. air under the front tires is eazy just jack the front of the hotrod up.
