July 05, 2008, 07:13:07 PM
| | |-+  Making good brake line flares..or trying to...*Update with Pics*
Author Topic: Making good brake line flares..or trying to...*Update with Pics*  (Read 996 times)
ValiantOne
Western MD
« on: November 04, 2007, 08:50:23 PM »
Can you guys give me some tips on making good brake line flares. I bought a flaring kit this weekend so I can start re-brake-lining my 66 Val.
I have been doing some practice flares on old 3/16's lines to try and get the process down. What I end up with looks like it may seal ok, but it sure ain't as pretty as the factory flares.
I have been very carfull to cut the line off square and chamfer the edges. But when I go to do the second "squish" with the tool, the flare seems to get lopsided.
What am I missing here?
Thanks!
Chris E.
Chris Evrard
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
doug 371
Re: Making good brake line flares.......or trying to..........
« Reply #1 on: November 04, 2007, 08:55:57 PM »
i suck at that too lol
loiq
« Reply #2 on: November 04, 2007, 09:04:24 PM »
I've tried many, many times, never been able to do it. Dunno I don't even think it's possible.
ValiantOne
Western MD
« Reply #3 on: November 04, 2007, 09:19:21 PM »
Well that gives me some confidence \/][
they really do look like they will seal ok, but I don't want to spend HOURS bending $$$ worth of line, just to have a DOT 3 sprinkler system when I am done Shocked
Chris Evrard
sycboi
« Reply #4 on: November 04, 2007, 09:28:29 PM »
Are you leaving too much line to be flared?  The amount of line should be exactly level with the step in the flaring die when the die is sat beside the protruding hardline after it's clamped in the tool...
-Michael
ski
« Reply #5 on: November 04, 2007, 09:30:30 PM »
-Michael
 agree
ValiantOne
Western MD
« Reply #6 on: November 04, 2007, 09:50:46 PM »
-Michael
Yep, I was real careful about that too.
Could it be that I was using old tubing? It wasn't rusty or anything.
Chris Evrard
sr71mopar
Santa Rosa, CA.
« Reply #7 on: November 04, 2007, 10:10:00 PM »
How are you cutting the tubing? A square cut with clean deburred edges helps.
Birdius Rapidus
« Reply #8 on: November 04, 2007, 10:39:19 PM »
I agree with Michael and others. Too much left to be double flared and the tubing will push off center. A tubing cutter (Ridgid pipe cutter) is the best way to cut your tube. And a quality double flare kit helps.
Also, do not tighten more than required. If you do, the tube with twist off center and sometimes split. I have successfully double flared stainless tubing on my Road Runner and Dart thanks to tips by B.B.D. memembers.
joesnow
s.e.pa.
« Reply #9 on: November 04, 2007, 10:47:25 PM »
It sounds like you have too much tubing sticking out of the tool. You only need the same length as the thickness of the double flare piece.Ream and file the tubing before you start also.
Long Island, NY
« Reply #10 on: November 04, 2007, 10:59:49 PM »
Add a drop of lube where the anvil swivels on the threaded shaft. I have a Snap on flaring tool and it worked a little funny til I did that.
dangerdawg
« Reply #11 on: November 05, 2007, 09:25:58 AM »
  mine did too. keep practiceing.
bbscamp
Ehm.....B5 Blue am I?
« Reply #12 on: November 05, 2007, 08:15:20 PM »
1:  make sure the line is level (the right length).  2:  put a drop of BRAKE ASSEMBLY LUBE between the die and line, and between the line and cone when forming the flare.
3:  a good quality tubing flare tool is what you need.  Those $19 Craftsmen type are awful.    They are only good for single flares in copper....not double flares in steel.  Get a good flare tool!!!  good luck
CudaDon65
« Reply #13 on: November 05, 2007, 08:25:41 PM »
agree agree
loiq
« Reply #14 on: November 05, 2007, 09:13:10 PM »
I think that's most of my problem, I just have a hardware store double flaring tool.
rharveysr
« Reply #15 on: November 06, 2007, 09:13:36 AM »
Brand name?  I need to order one for the tool box..
Rick
Long Island, NY
« Reply #16 on: November 06, 2007, 09:48:19 AM »
Snap on is good, I've also used a Ridgid... Pretty good too.
ValiantOne
Western MD
« Reply #17 on: November 06, 2007, 11:02:22 AM »
so far the only thing I haven't tried is the lube. I'll give that a go.
My flaring tool is from Autozone. It isn't the top jimmy, but over all it seems decent. I also have a spare "clamp part" from another set that I may try too.
I may get a better tubing cutter too. I have one of those mini deals. A pain to work with. I also tried a whizzer wheel and then trued everything up with a file. Because I do a lot  of small work on guns, I am VERY proficient with a file Wink
Guess I'll keep practicing.
I'd still like to know if you guys actually get "factory" looking flares when everthing works right?
Thanks,
Chris Evrard
Long Island, NY
« Reply #18 on: November 06, 2007, 12:58:49 PM »
I guess they look factory. Who cares what they look like? As long as they don't leak.
ski
« Reply #19 on: November 06, 2007, 01:49:21 PM »
Chris, This is what I use.  The flaring set is a MATCO but I've seen the exact same set with other name brands on it.  It's aways worked great for me.  I think they go for about 45 bucks new but I got mine at a swap meet.  The bender is a cheapo 20 dollar job.  I use the mini tubing cutter which is fine if it's a good one.
ski
69 GTS Clonvertible
GEAR+SLAMMER
« Reply #20 on: November 06, 2007, 02:45:45 PM »
Thanks,
I have the one from autozone or checker also, the only problem I seen was that the clamping tool that holds the tube creates a small bur at the seam area on the back side of the flare where the 2 halves of the tool come together, and I just filed it off. Also make sure the 2 halves of the tool are clamped down tight and flush. The lube is also good to use, I just used the drops of dot3 that were still in the lines. One last item on the old practice lines make certain the outside is clean and free of gunk, use some emery cloth to clean it. My .02
69CLONE
william
« Reply #21 on: November 06, 2007, 09:46:58 PM »
I have found Weatherhead flare kit to work best.
I got my at NAPA
73swinger
Blackstock, Ontario
« Reply #22 on: November 06, 2007, 10:22:10 PM »
ski
[/quote I absolutely hate those cheap ass benders. Everytime I've tried to used them on steel line, it kinks. As far as I'm concerned Rigid style benders work the best, and the flare tools with rollers in the anvil work best too...or some lube and some patience on the other type
Cpt Panzer
« Reply #23 on: November 06, 2007, 11:41:59 PM »
I found that with some of the cheaper kits when you leave the end to be flared at the same height as the first step on the die its actualy to much material try to set it slightly lower than the first step. also you can back the tool off and check your progress. with a double flare some times less is more
Dartsport
« Reply #24 on: November 07, 2007, 10:12:27 AM »
I use a Snap-On flaring kit, made by Blue Point. I have used it for over 20 years in my business. It works good. I taught my 11 year old son how to double flare brake lines this spring. I showed him how to do a double flare twice. Then I let him practice on some extra pieces of brake tubing. His 1st one, was the only one that wasn't good.......
Long Island, NY
« Reply #25 on: November 07, 2007, 11:39:03 AM »
Nice. My stepson is 16 and I was just able to teach him how to repair a flat on his BICYCLE. Big dope.
75Dart440
« Reply #26 on: November 07, 2007, 04:26:30 PM »
I have had good luck flaring mild steel brake line in 3/16 and 1/4 " with the el cheapo double flaring kits out there, but stainless is a whole-nother story.  One thing that helps with both types of metal, is to cut it square on the ends, and cut it using a method that limits the amount of work hardening on the end of the tube.  If you work harden the end, the last stage (double flare) is harder than hell to get straight.
Also be sure that there is no seam or flashing from the welded seam in the inside of the tube.  That will create more resistance on that side of the tube.  Some tubing is just plain inconsistent with it's wall thickness, which also causes this problem.  Stainless tubing is available in hard and soft as well.  The soft is obviously the better choice for double flares.
I ended all of my problems this past Sept while trying to fabricate stainless brake lines for my Dart.......I broke down and bought a MasterCool Hydra flare kit.  I threw my old flariing tool away!!  Never again will I go back to the old way of doing these flares!!!
1975 Dodge Dart Sport - 440
2000 Dodge Ram 1500 QC 4x4
fourspeed
Wisconsin
« Reply #27 on: November 08, 2007, 02:38:13 AM »
I got a K-D from NAPA. Works good most of the time. Once in while I get a egg-shaped flare.
I get the bulk brake line. Comes in a roll. It's easy to bend by hand without kinks.
ValiantOne
Western MD
« Reply #28 on: November 08, 2007, 12:32:27 PM »
Hey, thanks again for all the tips guys. I'll be out there on Saturday again, trying to get this brake system wrapped up.
I'll definitely post on how things went!
Smiley
Chris Evrard
rharveysr
« Reply #29 on: November 08, 2007, 05:56:21 PM »
We will be running brake lines and also solid fuel likes that we want to use AN filtting...I have heard that the AN fittings is 37* and the brake lines are 45*..is this true. If that is the case we will need 2 flairing tools.
Thanks
Rick
Pages: [1] 2  All Go Up Print
