Topic: Making good brake line flares..or trying to...*Update with Pics* (Read 1037 times)
*DB*
I've mated 37 degree AN flares to 45 degree flares on both steel & aluminum tube & never had one leak. One with steel tube is parked in my garage right now. That fuel system was built about 15 years ago. Never any leaks. My Dart has aluminum fuel line, has been together only 7 or 8 years. No leaks.
Personally, FOR ME, it's a non-issue, & I'll continue to do this on my own & my brother's cars. If it makes YOU feel better, then by all means get a 37 degree flare tool.
67 dartgts
Yeah I hate those dbl. flares also ...I caan usually get it done but i rather not ,  . One other tip be sure your cut is square to the tubing, I've gotten to the point of measuring the old ones and just buying new tubes. Not as expensive as you may think and it's right, with no high blood presurre on my part. Maynard
ValiantOne
Well it turned out to be the tool after all. Cheapie Advance Auto flaring tool SUCKED  I went over the the Snap On dealer and shelled out $120 for a nice Blue Point tool with a really nice tubing cutter. It made all the difference in the world as evidenced below. Thanks for all the help guys!!! Factory flares:  Cheapie Advance Auto tool flares:  Good Blue Point tool flares:
loiq
I think I need a new flaring tool.
jamesdart
ive had a few leakers, i thought the lisle flaring tool i bought was a good one, but id really did drive me nuts on mine and my brothers cars, and i cant tell you how many 3/16 dies i went through. i think im going to have to buy a new flaring tool too.
Good tools make the differance.
Cary Snyder 5.7L Hemi Cuda
uwee440
K-D from napa is a great flaring tool,I found that filing the outside of the line and tightning it just right works everytime.
Ray Barton Racing Engines
