January 09, 2009, 03:27:36 AM
| | |-+  one piece engine plate
Author Topic: one piece engine plate  (Read 376 times)
PO STREET DUSTER
« on: February 15, 2006, 08:43:09 PM »
     I just bought a competition engineering engine plate for my 440.  Its going into a 72 duster coupled to a 727.
     My Question is do I have to run a mid engine plate as well or will the front plate and trany mount be ok???
lake worth, florida
55robert@comcast.net
Re: one piece engine plate
« Reply #1 on: February 15, 2006, 08:48:46 PM »
the front only will be just fine.
sickt7cuda
« Reply #2 on: February 17, 2006, 11:11:56 AM »
Like Bob said, the front plate alone will be sufficient.  The Mid-plates are really only necessary with big HP/TQ combos.  Since you won't be using the motor mounts any longer, you should also consider using an engine limiter to keep the motor plate from flexing during hard acceleration.  Without the limiter, you run the risk of cracking the tailshaft housing on the trans.  S&W Racecars has a nice limiter kit for a good price.
505 - 400 block
EZ-1's, 4.56 gear, 8" PTC 4500 stall
best of 1.402 60', 10.338 @ 128.73
lake worth, florida
« Reply #3 on: February 17, 2006, 12:35:34 PM »
another thing that will limit the engine movement a lot and is a good upgrade is a poly trans mount.
Tubbed440
Suspension NinJa
« Reply #4 on: February 18, 2006, 10:58:16 AM »
I second the travel limiter and the poly mount is a great idea.  I ran full front plate, travel limiter and stcok trans mount for 4 years on the street and strip in my tubbed duster and had no problems.
PO STREET DUSTER
« Reply #5 on: February 21, 2006, 12:26:26 AM »
     Thanks guys this sight rocks.  Everyones so helpfull!!!  Is an engine limiter just a bracket from the top of the plate to the frame rail
Dartsport
« Reply #6 on: February 21, 2006, 09:02:59 AM »
A engine limiter would go from motor to frame, to keep motor from moving front to rear. Here is a picture of mine. It is the gray rod , bolted to the motor mount boss, rod going to the front is bolted to the frame.
505 cu. in. , Alston chassis, CRT trans, FBO Ignition,  9.451et, 141.91mph, 1.278 - 60 foot, SO FAR!!
Avenger
« Reply #7 on: February 21, 2006, 05:18:13 PM »
I want to suggest that you tie the engine down forward and aft with a front mount. As you accellerate the crank trys to go forward and when you let off it trys to screw backwards. It will make a tranny 3 piece at the finish line.
I made a mount off of the K-frame and tied to the front of the block but there are several ways to do it.
