January 09, 2009, 03:17:33 AM
| | |-+  Whats the best way to block the heat crossover?
Author Topic: Whats the best way to block the heat crossover?  (Read 774 times)
1968rt
« on: November 20, 2007, 07:00:37 PM »
Ive heard that they make a valley pan gasket with a block off. Someone else said they make plugs, and another person said Jib Weld?  What is the CORRECT way to block it?? hammer
deadly dart
Original Hurst Hemi Dart Owner
deadlydart426
Re: Whats the best way to block the heat crossover?
« Reply #1 on: November 20, 2007, 07:41:43 PM »
Use "Rutland" black furnace cement. Fill the passage in the head completely and shape the bowl area before it hardens. I think I bought the last can at Ace Hardware. This contains a lot of iron particles and will not burn out.  For a while you could not buy small amounts, only drums full.
1969 Dodge Dart 500 CI B1 motor 727 rotarized backbraced ford 9 inch 4.56 gear times soon to come!
1973 Dodge Dart Sport 360/727/ 8.75 3.91 gears 4200 stall converter 12.58 @ 106
1972 Dodge Dart 440/727 project
Capt Jack
« Reply #2 on: November 20, 2007, 07:53:28 PM »
old school solution:
we filled it the gap under the manifold with rolled and wadded up alum foil.  didnt last forever but  then again, we weren't planning for living forever.
it did however seem to make a difference
jamesdart
« Reply #3 on: November 20, 2007, 08:51:54 PM »
yeah they make a valley pan with it blocked off, i forget the number. i bought th emopar one thinking it was it but it came with th estupid plates i guess you are supposed to fit them to the port and epoxy them in?
Steve DeTar
« Reply #4 on: November 20, 2007, 09:32:21 PM »
Which engine?
Engine by DeTar
chryco
« Reply #5 on: November 20, 2007, 10:36:37 PM »
I believe there are intake gaskets available that`ll do that for you. Maybe someone can remember who makes em'
    Chryco Wink
d55dave
« Reply #6 on: November 20, 2007, 11:27:14 PM »
Bought one recently from Chrysler - it was advertised as an intake gasket with exhaust crossover blocks (for a 440). I went and picked it up, looked good in a nice mopar box and all but I was incredibly dissapointed when I opened it up and it contained a stock gasket with the holes, and 2 pieces of sheet metal aprox 3/4" by 2" to be glued, I assume, over the passages. To top it all off the 2 pieces were at least 2 to 3 times thicker than the gasket. It didnt look like the hot set up to me. I ended up cutting a couple pieces of thin stainless and siliconing them over the passages.
I dont recomend the Chrysler gasket, but I do believe there is a fel pro one (or perhaps someone else makes it) that has the passages blocked.
I know for a fact that fel pro makes a performance intake gasket for small blocks with the passages blocked and a nice raised silicone bead around the intake port & coolant holes.
David
sr71mopar
Santa Rosa, CA.
« Reply #7 on: November 20, 2007, 11:46:10 PM »
I have a Felpro valley pan for my RB that blocks the crossover. Seams like the easiest way.
qkcuda
Caledonia, ON Canada
« Reply #8 on: November 21, 2007, 08:46:02 AM »
Yep, I use the fel-pro on my 400.  You have to look in their performance section, not in the standard listings.
mopfried
« Reply #9 on: November 21, 2007, 08:56:55 AM »
It looks like most of the big block aftermarket intakes dont have the cross over in them. My M1 or torker dont have them.
west
« Reply #10 on: November 21, 2007, 11:03:06 AM »
yup,fel pro has two lines,the performance version "blue" i think has em blocked.
moparn1
Full Monty Racing
« Reply #11 on: November 21, 2007, 06:13:26 PM »
pretty sure it's fel-pro part#1214 I use them on my 383 not sure the RB no.
bow chicka bow wow
Ft. Worth TX.
« Reply #12 on: November 21, 2007, 09:18:07 PM »
I agree with the above.
Cary Snyder
5.7L Hemi Cuda
Pro Street dart
« Reply #13 on: November 23, 2007, 11:59:41 AM »
Fel-Pro  p/n 1215 has the heat crossover blocked without the use of plate. It's just the bathtub. You get 4 paper gaskets w/ this p/n also.  I did not use them. RB.
H/P Intake Gasket
Chrysler 413, 426, 400 V8 Engines
Valley Pan Gasket w/ Blocked Heat Crossover and Four Facing Pieces
Port Size: 1.23: x 2.27"
Thickness: Facing .030"; Valley Pan .015"
speedymopars
Fighting illegal immigration since 1492!ProudSioux
« Reply #14 on: November 24, 2007, 10:51:17 PM »
Love to find some for a B, but no luck so far. Only an issue for me when running the single plane, the tunnel ram doesn't have the passages thankfully.
Ciscodog
« Reply #15 on: November 25, 2007, 12:03:10 AM »
I used to take a dremel and grind a step around the crossover opening on the manifold.  Put a piece or .060" aluminum in there with red rtv and forget about it.
ucdcrush
« Reply #16 on: November 25, 2007, 12:24:54 AM »
1214 is the B version. I just got the # off one in my garage off my busted 383.
383man
« Reply #17 on: November 26, 2007, 12:56:18 AM »
I always have my intake crossover's welded up. My welder buddy charges me $25. bucks and I never worry about it again.  Ron
My car , 63 Sport Fury Max Wedge wanna be......11.52 @ 116.84 so far !  Sons street car 400 Dart......11.45 @ 117.73.
