October 07, 2008, 06:02:26 PM
| | |-+  1969 dart rear end
Author Topic: 1969 dart rear end  (Read 694 times)
1969 360 DART
1969 dart rear end
« on: November 22, 2007, 01:54:47 AM »
. hi                 im i have a 1969 dart the car has been mini tubed . i would like to know what size do i cut my rearend to i have a set of weld wheels 15/10 with 3 1/2 backing space please help i will b running a 11 inch slick thank you
Re: 1969 dart rear end
« Reply #1 on: November 22, 2007, 08:01:44 AM »
Pull the rear out, put the tires under there where you want them, measure between the wheel axle surfaces and send the whole mess off to Moser.  They'll make it right if you give them the overall width.
mark8denny
Chicagoland way South
« Reply #2 on: November 22, 2007, 10:12:13 AM »
1969 Barracuda coupe, mini tubbed , leaves moved in 3" , stock quarters , 15x10 centerlines , 8 3/4 50" drum to drum
Rides : 1969 Barracuda hardtop
          1967 Sunbeam Alpine
          1994 Lincoln Mark 8 , 355 RWHP
          2003 Ford F 150 supercrew
« Reply #3 on: November 22, 2007, 11:34:34 AM »
Mine was 48.5. I did it the same way carter is tlking about. I put the wheels under the car. Made all the measurements. It is the only way.
mark8denny
« Reply #4 on: November 22, 2007, 11:39:18 AM »
me too , the only way is with the tires mounted too  , 28 x 10.5 et Drags , fit perfect , wheel offset makes the difference
          1967 Sunbeam Alpine
1969 360 DART
« Reply #5 on: November 22, 2007, 02:19:10 PM »
what backing space are your rims???
mark8denny
« Reply #6 on: November 22, 2007, 02:23:40 PM »
Car is at the shop , don't remember , will measure tuesday
Measured today (tuesday) On MY car - wheel backspace is 3 1/4  ,drum to drum is 50" ,  I have little more than 1 3/4 between sidewall and inner wheel well
make sure you measure YOUR car if you want it right !
I think a Dart has narrower wheelwells , my 70 did !
goodluck with your project
          1967 Sunbeam Alpine
CudaDon65
« Reply #7 on: November 22, 2007, 03:07:05 PM »
agree agree agree.Thats what I did and it worked real good. !nanr
mark8denny
« Reply #8 on: November 27, 2007, 01:25:32 PM »
updated my post , have to resize pic's will post later when I have time to figure it out !! Frustrated
          1967 Sunbeam Alpine
1969 360 DART
« Reply #9 on: November 27, 2007, 11:16:00 PM »
thack you all
