Topic: seam sealer (Read 678 times)
Darren
What kind of seam sealer are you guys using for body sealing? Thanks
Yea I need to know too.
mrspeeddemon
I use 3M Brushable Seam Sealer- I think it was like $25 at the paint store
I used brushable seam sealer from The Eastwood company, great stuff...Part#31028 ZP $19.99 a quart...
dmn71
Coal Valley, Illinois
Same as mrspeeddemon, part #08656
The 3m brushable sealer is what my buddy's shop uses....
Dartsport
Napa# 4313 neutral color, comes in a tube for a caulking gun.
AAOUTLAW
it all depends on the type of seam is is....some look better with a flowable " drip check " type of sealer like where the quarters seam in the trunk opening area near the sail panels. Then other seams like where inner wheel housings " tubs" meet the floor and in the firewall and floor area seal up very well with 3M ultra pro urethane seam sealer( this stuff is the SHIT)... the only down side is that it needs a special applicator gun PN 08398. This 3M stuff is the best i have ever used and is heavy bodied enough to booger up fairly large gaps.
rharveysr
We will need some kind of stuff when we mini-tub the Dart. What kind of stuff can we use to float the inside of the wheel wells so that you cant tell they were enlarged??? I know the tires will fill it up but just want to make it look clean...
Halfaed
I used some stuff from United, comes in a caulk tube also. I don't like the brush on stuff.
sweatybetty
i used hurculiner on the entire bottom of the car. it a brush on bed liner. tough stuff
