September 05, 2008, 07:16:40 AM
| | |-+  Yukon axles
Author Topic: Yukon axles  (Read 744 times)
sr71mopar
Santa Rosa, CA.
Yukon axles
« on: February 16, 2006, 01:29:50 PM »
Has anyone ever used an stuff from Yukon? I need axles, and Mancini sells Them for 140 each with bearings already on them. Seems like a good deal to me.
1DART440
Re: Yukon axles
« Reply #1 on: February 16, 2006, 01:57:50 PM »
I just ordered a set of 28" ones, stock length. I will pick them up in the USA on Saturday. I can tell you what they look like at that time. Terry
AA-slingshot
yeah...it's got a HEMI
Re: Yukon axles
« Reply #2 on: February 16, 2006, 02:34:54 PM »
they work just fine.....unless your building fueler lol
Ryan (Strange246)
Merrimack NH
strange246 strange2462000
Re: Yukon axles
« Reply #3 on: February 16, 2006, 05:08:07 PM »
I have them got them from Doctordiff, a fellow board member for the same price...havn't run them yet but look good...
Dr. Hunter S. Thompson
sr71mopar
Santa Rosa, CA.
Re: Yukon axles
« Reply #4 on: February 16, 2006, 05:21:38 PM »
I ordered them.
moparteacher
Re: Yukon axles
« Reply #5 on: February 16, 2006, 05:46:44 PM »
I purchased mine from Moser. They were $299.00 with bearings and studs.
Moparteacher
Moparteacher
dodgee
Re: Yukon axles
« Reply #6 on: February 16, 2006, 05:51:35 PM »
just recieved a set from mancini 28" std  a body length with bearings already pressed on, look fine but have not installed yet.
Ft. Worth TX.
Re: Yukon axles
« Reply #7 on: February 16, 2006, 07:03:07 PM »
I used Moser street axels. They were 199 with studs. I did not getthem with bearings due to the fact that they use green bearings and I did not want that on the street.
Cary Snyder
5.7L Hemi Cuda
dmn71
Coal Valley, Illinois
Re: Yukon axles
« Reply #8 on: February 16, 2006, 11:07:11 PM »
Bakaruda, Why not green bearings on the street?  I'm looking to get some axles soon.  Steve
DBU440GT
Re: Yukon axles
« Reply #9 on: February 17, 2006, 11:33:05 AM »
An old friend(Lou Mancini) explained it this way once: And I quote." Be careful using Green (ball bearings) on the street.  They are not designed to stand much side load, and very low impact load.   Only radial load.  If they were meant to be used on the street, Chrysler would have done so.  It would have been a cost savings and definetly a labor savings since no end play adjustment would have been needed.  The tapered bearings have more area and are designed to stand the side loads experienced on the street.  In a drag car. the axle only sees radial and torsional loads......unless you get sideways!!  End loads from impact will Brinnell the bearing and this will cause noise then a failure. If you are a cruiser, probably will be no problem, just understand the risk."
   Believe me this guy knows MOPARs  Wink
abodyjoe
South Jersey...
abodyjoe
Re: Yukon axles
« Reply #10 on: February 17, 2006, 12:17:05 PM »
  i would love to know the truth about that...  i have heard that over and over again..  but i have used those green bearings on quite a few cars with no problems...  heck they have been on my yellow dart for about 10 years and tons of hard street miles and they have never been a problem.. i know of a few friends that have had them on their cars also with tons of hard street miles and have never had a problem....
DBU440GT
Re: Yukon axles
« Reply #11 on: February 17, 2006, 01:23:35 PM »
Joe I also wonder too. In a car the weight might factor into this and let them live. But consider a pick up with a load(lot of them had 8 3/4s), The pressures are sure to increase right? A van also. As they were ment to haul stuff. Cars arent ment to carry as much weight in the trunks. So the factory couldnt justify two different build processes for the 8 3/4 for trucks vs cars so they chose the stronger of the two across the board? This a good question for a rear end expert to put to rest. I personaly havent used the green bearings yet as I dont mind checking and correcting end play once in a while and never had a failure with the OEM design. Maybe the factory design is overkill and the greens are fine for cars but there must have been a reason?.....
68GTconvert
Re: Yukon axles
« Reply #12 on: February 17, 2006, 01:34:06 PM »
I found a set of new moser axles with green bearing locally for 150. Got lucky.
68 440-convertible. 67-Dart-340-4 speed.
"Beer is proof that god loves us and wants us to be happy" Benjamin franklin
68GTconvert
Re: Yukon axles
« Reply #13 on: February 17, 2006, 01:34:37 PM »
Oh but the yukons look like nice axles.
Crazy68Dart
Re: Yukon axles
« Reply #14 on: February 17, 2006, 02:02:36 PM »
That is interesting.  Ford 9" rears run sealed ball bearings, right?
Andy
Ft. Worth TX.
Re: Yukon axles
« Reply #15 on: February 17, 2006, 04:54:26 PM »
Green bearings on the street are for people who do not know how to set end play!!!!!!!!!!!!!!!!
Cary Snyder
5.7L Hemi Cuda
65prostreet
Re: Yukon axles
« Reply #16 on: February 17, 2006, 05:31:23 PM »
yea, green bearings are easier but not limited to the ignorant
1DART440
Re: Yukon axles
« Reply #17 on: February 17, 2006, 08:05:46 PM »
The Yukon axles I bought said, "green bearings only". No choice to be had. I haven't seem a green bearing, I'm getting mine tomorrow. Are they a sealed ball bearing or a straight roller like some of the newer axles ?
dmn71
Re: Yukon axles
« Reply #18 on: February 17, 2006, 08:38:07 PM »
Thanks for all the input!  Some good points to think about.  Will be honest have never set end play.  Thanks Steve
65rbdodge
jeff44044mag
Re: Yukon axles
« Reply #19 on: February 18, 2006, 02:59:55 PM »
i bought yukon axels for my dart. they fit and have not broke, so i guess thay are good. i have green bearing in both my cars and have not had any problems. i think that the "green bearings are bad" idea is an urban legend. i`ve heard it on the internet, but never saw it first hand.
65 coronet 440/4 speed/9.75
71 dart custom 4 door 400/727/8.75
03 dakota 239/5 speed/8.25
JD451
Re: Yukon axles
« Reply #20 on: February 18, 2006, 04:00:10 PM »
Its a bummer they don't make them for B body rearends. though my stock axles are the big ones and there holding up just fine.
sr71mopar
Santa Rosa, CA.
Re: Yukon axles
« Reply #21 on: February 18, 2006, 04:02:15 PM »
Mancini also sells them in 30 inch. I think that is B-body.
JD451
Re: Yukon axles
« Reply #22 on: February 18, 2006, 04:32:38 PM »
I"ll call Mancini and find out, from what i was told they don't make them, the 30 inch might be for E body.
