Topic: trunk w/ fuel system inside topic (Read 377 times)
64dartsb
If your dreaming of your car then it's your dream car
64 dart stock appearing, grocery getter, 360 2.02 in, 1.60 ex victor jr, aeromotive fuel system. msd dist, coil, wires, 6a, 125 shot of nitrous hedman 1 7/8 fenderwells 3 in exhaust / 904 quarter stick, reverse manual, / 8 3/4 3.91, suregrip
wedgie
I doubt that you could ever pass any safety inspection with your proposed setup. In case of an accident, you wouldn't be a very happy camper with gasoline in the cab area. I guess if you completely sealed the trunk from the passenger area it may be OK. Ever see the old photos of Pintos getting rear ended? Be safe and do it right.
64dartsb
It will be held down by straps just like the ones that summit sells for fuel cells, the car will have a firewall to completely seal off the trunk
75Dart440
I just had a perfect example of why it would be a bad idea to mount the fuel system in the trunk (exception to the cell): I ordered a new Holley HP-125 billet fuel pump and due to a manufacturing flaw the thing pumped fuel out through the weep hole at the motor assembly. Had it been in the trunk, I may have never caught the leak before the fuel would have entered the motor/brush area of the pump and caught fire.
According to Holley tech support, that weep hole is there to prevent fuel from getting to the motor housing in the event that the pump fails. Looks like it worked this time. Jegs sent me a new pump, just arrived today. Hope it works better than the first one!!!
If you really want the pump to be up that high in the fuel system, you could build a raised floor around the pump so in the event of a leak it would still leak to the ground and not in the car.
tophat
Ever been to a demolition derby? 99% of those cars run a plastic boat tank where the back seat used to be. Personally, my 63 Dart (street car) has a 6 gallon boat tank in the trunk held in with a ratchet strap  though I do have a vented cap with the hose run out the back. Ever seen a 61~71 Dodge pick up? The tank is right behind the seat. BTW Pintos blew up because the government WANTED them to. The feds had a grudge against ford and it was their way of getting even. The "approved " fix was a roughly 18" by 6" piece of plastic, thats it. It was very very rare for a pinto to blow up outside of a test facility. The Pinto was one of the best cars ford ever built. Not that I am a ford fan (I'm not) but I would have another early Pinto in a second. TopHat
64dartsb
sounds like nobody likes the Idea of the pumps in the trunk. I just finished it today and everything look really good. I ended up putitng the pumps on opposite sides so the whole thing looks symetrical. I'm really happy with everything but the straps, I'm going to redo those next time I get dirty. I'll post some pictures up in the next few days.
75Dart440
Ever been to a demolition derby? 99% of those cars run a plastic boat tank where the back seat used to be. TopHat
True, but demo derby cars don't generally have to be concerned with going upside down at high speed like a street car would.  The fuel tank in the truck cab design was just a plain poor design from a safety standpoint. Take a hard hit to the cab side and you could be bathing in gasoline. How many of those old trucks smelled like gasoline inside the cab!!?? I'm not saying that either way is the correct way to plumb the fuel system, just that there are pro's and con's to both ways. I would at least weld in a metal bulkhead behind the rear seat and seam seal it for safety reasons. Doesn't NHRA require a metal bulkhead be placed between the trunk and the main passenger compartment if running a fuel cell in the trunk?
mopowers
Doesn't NHRA require a metal bulkhead be placed between the trunk and the main passenger compartment if running a fuel cell in the trunk? Yes
